Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 30
  1. #11
    Full Member
    AutoCAD 2016
    Aug 2016
    37
    Quote Originally Posted by Lee Mac View Post
    Here is an example:
    Code:
    (defun c:px ( / cmd ent enx ped )
        (setvar 'errno 0)
        (while (/= 52 (getvar 'errno))
            (setvar 'errno 0)
            (setq ent (car (entsel "\nSelect polyline <exit>: ")))
            (cond
                (   (= 7 (getvar 'errno))
                    (prompt "\nMissed, try again.")
                (   (null ent)
                    (prompt "\nExit.")
                (   (/= "LWPOLYLINE" (cdr (assoc 0 (setq enx (entget ent)))))
                    (prompt "\nSelected object is not an LWPolyline.")
                (   (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (cdr (assoc 8 enx)))))))
                    (prompt "\nSelected polyline is on a locked layer.")
                (   (setq cmd (getvar 'cmdecho)
                          ped (getvar 'peditaccept)
                    (setvar 'cmdecho 0)
                    (setvar 'peditaccept 1)
                    (command
                        "_.explode" ent
                        "_.pedit" "_m" "_p" "" "_w" (cdr (assoc 43 enx)) ""
                    (setvar 'peditaccept ped)
                    (setvar 'cmdecho cmd)
    WOW!!! Now that is the right way to do it!!!
    on a side note, i keep re-writing and re-writing my code cuz i kept getting an error. turns out the global was not set and i kept getting an error.
    after i ran yours and it also didn't work, i knew something was wrong. never did i think to check if the global width was set.
    maybe there could be a variable to select either starting width or ending width if global is not set.
  2. #12
    Full Member
    AutoCAD 2016
    Aug 2016
    37
    (command
    "_.explode" ent
    I learn more from your code then from the book I'm reading.
    I see now that I don't need to setq pw for assoc 43, i can simply invoke assoc 43 when i need that number.
    I'm still a caveman in coding, but i'm trying to make that fire burn. that should be my CADTutor motto. lol.
  3. #13
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,569
    Quote Originally Posted by Grrr View Post
    Code:
    (/= (cdr (assoc 70 (entget (tblobjname "LAYER" (cdr (assoc 8 enx)))))) 4)
    I might need to study deeper this logand function as its not the first time I see its in use.
    Indeed - DXF group 70 is typically bit-coded and therefore may not be equal to 4 if locked with other properties set (for example, test your code with an object residing on a locked layer which is frozen in new viewports).
    Quote Originally Posted by RubberDinero View Post
    That's great to hear!
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  4. #14
    Full Member
    AutoCAD 2016
    Aug 2016
    37
    (command
    "_.explode" ent
    Where the following code is
    Code:
    would it be possible to make that a variable and add an (if parameter stating that if the Constant width is null and (cdr (assoc 40)) is equal to (cdr (assoc 41) then width would be set to starting width.
    If different, ask user input to choose either start or end
    i.e. (initget "Start End"
    where start is (cdr (assoc 40)) and end is (cdr (assoc 41))
    i think that would wrap up this lisp of all errors.
  5. #15
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,456
    That was exactly my thought, I wasn't sure how to structure your answer as a question in my previous post, but you answered already. (english is not my first langugage).
    Thank you for elaborating!
  6. #16
    Super Member
    Civil 3D 2015
    Aug 2015
    508
    Code:
    Hint, look at dxf group codes 40 and 41 to find the starting and ending widths. Just need to put in a conditional statement where if dxf group code 43 is null, then move onto the 40 or 41 depending on your preference.
  7. #17
    Full Member
    AutoCAD 2016
    Aug 2016
    37
    Code:
    (defun c:px2 ( / cmd ent enx ped pw1 )
        (setvar 'errno 0)
            (setvar 'errno 0)
            (cond
                (   (null ent)
                    (prompt "\nExit.")
                    (setvar 'cmdecho 0)
    		(if (= (cdr (assoc 43 enx)) nil)
    			(if (= (cdr (assoc 41 enx)) (cdr (assoc 40 enx)))
    				(setq pw1 (cdr (assoc 40 enx)))
    				(initget "Start End (cdr (assoc 40 enx)) (cdr (assoc 41 enx)))
    				(setq pw1 (getkword "\nEnter an Option (Start/End): "))
    			(setq pw1 (cdr (assoc 43 enx)))
                    (command
                        "_.explode" ent
                        "_.pedit" "_m" "_p" "" "_w" pw1 ""
    I tried my caveman coding, but is it not possible to have an "IF" statement within an "IF" statement? or did I write the "(=" statement wrong?
  8. #18
    Full Member
    AutoCAD 2016
    Aug 2016
    37
    Code:
        (setvar 'errno 0)
            (setvar 'errno 0)
            (cond
                (   (null ent)
                    (prompt "\nExit.")
                    (setvar 'cmdecho 0)
    				((initget "Start End (cdr (assoc 40 enx)) (cdr (assoc 41 enx))") (setq pw1 (getkword "\nEnter an Option (Start/End): ")))
                    (command
                        "_.explode" ent
    HAD FORGOT TO PUT A END QUOTE!!! LOL!
    But now when i do getkword it doesn't accept Start or End, it says invalid.
  9. #19
    Full Member
    AutoCAD 2016
    Aug 2016
    37
    i know see that initget are the acceptable keywords. now i need to set up the if statements.
  10. #20
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,456
    RubberDinero, check this:
    http://www.lee-mac.com/promptwithdefault.html
    then check this (especially the last example code - for your case):
    http://www.afralisp.net/autolisp/tut...nditionals.php
  1. [LISP] Scaling just the "x" and "y" axis
    By chiimayred in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Dec 2017, 04:49 pm
  2. HELP to include "AcDbAlignedDimension" code for a "Dimension deleting" LISP
    By vernonlee in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Apr 2015, 04:03 pm
  3. Automatically updating "defined width" attributes for MTEXT?
    By Comatosis in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Dec 2011, 09:59 pm
  4. Polyline global width keeps showing up as 1"
    By ammobake in forum AutoCAD General
    Last Post: 4th Jun 2009, 10:52 pm
  5. Finding the "width" of a block (.NET)
    By askrius in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Sep 2008, 10:21 pm
Tags for this Thread
