Greendamo Posted September 14, 2016 Share Posted September 14, 2016 Hi, I really need help with this! im trying to loft a solid along a 3D Spline and I just keep getting bad results. Please see the drawing attached. Any help would be fantastic! thanks in advance. Regards Damian. Loft test.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 14, 2016 Share Posted September 14, 2016 (edited) This is what I got. Does it look the same or different than what you got? Where is the area of "bad results" you are referring to? It could be you need to add a couple more circular profiles to smooth out your model. This is the result when I added five more circular profiles. Look any different to you? Edited September 14, 2016 by ReMark Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 15, 2016 Share Posted September 15, 2016 I see I messed up on the last image (red) I loaded so I did it over. Quote Link to comment Share on other sites More sharing options...
