samifox Posted September 20, 2016 Share Posted September 20, 2016 hi, i want to use a elliptical usc, for example, i have an ellipse as a path, now i have an object i want to move 100cm left, i want this object to be moved along the ellipse path rather than the world ucs, how can it be done? Tx Shay Quote Link to comment Share on other sites More sharing options...
danellis Posted September 20, 2016 Share Posted September 20, 2016 A work-around rather than a solution, but: make sure PELLIPSE is set to 1 and trace over the ellipse (this creates an ellipse formed from polylines). Break this new polyline at your starting point (i.e. where the object you want to move is) Use the lengthen command to set the length of your ellipse section to the distance you want to move, and use this as a guide for the new object position. dJE Quote Link to comment Share on other sites More sharing options...
samifox Posted September 20, 2016 Author Share Posted September 20, 2016 hi, i have tried it, but it always looking to establish a circle, its ignores the angle of the ellipse, shay Quote Link to comment Share on other sites More sharing options...
