Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Full Member
    AutoCAD 2015
    Mar 2014
    Amsterdam
    30
    Default Copy text into same place but in different layer
    Hi all,
    I need to translate a selction of (130) details (all different dwg files) into 6 languages.
    So what I wanted to do is copy all the text and paste them 6 times in the same location but all in 6 different layers. So for english the layername would be like Text_English, for German Text_German etc.
    How would you do this?
    Or maybe someone has a routine for it allready
    Edit:
    I already have a tool to export the text to excel and import it back into autocad after translation.
    Gr. Wesley
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,862
    Please refrain from double posting as it just causes confusion. Thank you.
    I'm retired now.....not dead. I have a few working brain cells left.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,800
    A quick put together no checking for layers existing etc.
    Code:
    (defun c:test ( / oldsnap ss x obj)
    (setq oldsnap (getvar "osmode"))
    (setvar "osmode" 0)
    (setq ss (ssget '((0 . "Text"))))
      (setq obj (ssname ss (setq x (- x 1))))
        (command "copy" obj "" "0,0" "0,0") ; repeat these 2 lines as required
        (command "chprop" "L" "" "layer" "German" "")
    (setvar "osmode" oldsnap)
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,490
    EDIT: Removed previous suggestion, try this instead:
    Code:
    (defun C:test ( / *error* add c svrs LayNames s enx )
    	(defun add (n i) (repeat n (setq i (1+ i))))
    	(if (not c) (setq c 0))
    	(defun *error* (msg)
    		(if svrs (mapcar 'setvar (list 'cmdecho 'clipromptlines) svrs)) (princ)
    	(setq LayNames ; type your languages here ("Text_" prefix will be added automatically)
    		(list
    			"English" "German" "Spanish"
    			"Russian" "Serbian" "Bulgarian"
    	(setq svrs (mapcar 'getvar (list 'cmdecho 'clipromptlines)))
    	(mapcar 'setvar (list 'errno 'cmdecho 'clipromptlines) '(0 0 2))
    	(mapcar
    		(function
    			(lambda (x / )
    				(or
    					(tblsearch "LAYER" x)
    						(entmakex
    							(list
    								(cons 0 "LAYER")
    								(cons 100 "AcDbSymbolTableRecord")
    								(cons 100 "AcDbLayerTableRecord")
    								(cons 2 x)
    								(cons 70 0)
    								(cons 62 (setq c (add 15 c)))
    						(princ (strcat "\nCreated layer: " x " !"))
    				); or
    		(setq LayNames (mapcar '(lambda (x) (strcat "Text_" x)) LayNames))
    	(while (/= 52 (getvar 'errno))
    		(setq s (vl-catch-all-apply (function ssget) (list "_+.:E:S" (list (cons 0 "*TEXT")))))
    		(princ "\nSelect Text to Copy above the different layers")
    		(cond
    			((or (= 7 (getvar 'errno)) (null s))
    				(princ "\nYou missed, try again!")
    				(setvar 'errno 0)
    			((not (vl-catch-all-error-p s))
    				(if (setq enx (entget (ssname s 0)))
    						(setq s nil)
    						(foreach x LayNames
    							(entupd
    								(entmakex
    									(subst (cons 8 x) (assoc 8 enx) enx)
    						(princ "\nCopied the layers above the selected text !")
    			(T (setvar 'errno 52))
    		); cond
    	); while
    ); defun
    Still theres a issue, since the user can't exit the selection loop by pressing ENTER .. but I'm lazy to figure it out.
  5. #5
    Super Member
    not applicable
    Jun 2016
    701
    @Grrr:
    Hmm...
    Code:
    (add 11 15) => 26
    Code:
    (+ 11 15) => 26
    BricsCAD 18
  6. #6
    Super Member
    not applicable
    Jun 2016
    701
    Quote Originally Posted by Grrr View Post
    That is a pity.
    BricsCAD 18
  7. #7
    Full Member
    AutoCAD 2015
    Mar 2014
    Amsterdam
    30
    Thnx Grrr!
    This is a great start.
    in order to use this in a script, I would like to skip the selection of each text bij selecting all text in the drawing which is in a certain layer.
    So how do i implement the following in the script above?
    HTML Code:
    (setq s (ssget "x" '((0 . "TEXT,MTEXT")(8 . "AAc-0-TEXT"))))
  8. #8
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,490
    Quote Originally Posted by Roy_043 View Post
    @Grrr:
    Hmm...
    Code:
    (add 11 15) => 26
    Code:
    (+ 11 15) => 26
    Thanks, at first I tried to use the 1+ function, and completely forgot about the DIESEL functions.
    Btw I have everytime this "exit with enter" issue, while forcing the user to select.
    Unfortunately from where I write these codes, I can't test this behaviour (although I try any kind of checks like: vl-catch-error-p sslength (= 'pickset (type ...)).
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,800
    Wesley just replace the ssget line in my code above with yours ICalled the selection set ss so easiest is change you "s" to ss
    Add the two lines for the other languages required required.
    Again I have not put in the add new layer names it's quick to do anyway.
    Grr your code is a bit long winded, no disrespect, Not sure about a couple of things in it ? Clippromptlines
    Grr a little trick if you use command -la m layer1 m layer2 etc if it exists you do not get an error and lisp will continue whilst this is not really good programming it's quick and simple.
    Your correct the chprop show my age.
    I hate iPads makes my typing even worse.
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,800
    A script is just that a Lisp is also just that. A Vba is a Visual Basic program a c# is also a high level language now preferred is .Net
    Sorry but so many now call lisp coding a script.
  1. Separate/copy layer to other place by user pick point then sorting them..
    By nalsur8 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Oct 2015, 01:11 am
  2. label line with layer name and place text
    By sroberts in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Nov 2014, 12:28 pm
  3. Copy this from one place to other
    By sham in forum AutoCAD Beginners' Area
    Last Post: 26th Dec 2011, 01:41 am
  4. Place Leader line With Text(Error Layer)
    By johnpieter in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jun 2011, 03:34 am
