ktbjx Posted September 22, 2016 Share Posted September 22, 2016 the process im doing is very time consuming. NOTE: white polylines have elevations the brown ones is the road (which i need to draw using lines) create POINT and snap it to the white polylines to get elevation of the first point and i create another POINT and snap it to the closest white polyline, to get the next point then i create LINE, snap it on the 2 POINTS with elevation and DIV aand just make assumptions on how many point i will use then i off snap. then i move every point to the brown polylines then after that i delete the temporary line i use to DIV the points then i draw LINES again and snap it to the points i moved on the brown polylines to get the start and end Z... i will add the map im doing to make it easier to understand... is there an easier way to create the roads???? or am i on the wrong forum? i tried deleting some part to fit o upload sorry road (2).dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 22, 2016 Share Posted September 22, 2016 This is a continoulsy repeated question. Some else asked the same question last month. If you dont have access to Civ3d etc then search for free civil contour & road design software, Cadtools, ezysurf I forget the others. Its worth emailing to someone and paying it takes only minutes to do. Quote Link to comment Share on other sites More sharing options...
ktbjx Posted September 22, 2016 Author Share Posted September 22, 2016 This is a continoulsy repeated question. Some else asked the same question last month. If you dont have access to Civ3d etc then search for free civil contour & road design software, Cadtools, ezysurf I forget the others. Its worth emailing to someone and paying it takes only minutes to do. autocad CIVIL 3d can i use that??? ill try to download it, thanks mister Quote Link to comment Share on other sites More sharing options...
halam Posted September 22, 2016 Share Posted September 22, 2016 I noticed the braun lines (road) is created with a 2d polyline. That's just on z=0. The vertexes need to have a z, you can do that with 3d polylines. Extrude the road to intersect with the landscape. etc. You might as well take a look at the triangulate function. Get familiar with meshes and modelling solids .;-) Civil3D has great functions for road design http://www.theswamp.org/index.php?topic=9042.msg555712#msg555712 (just the last heading here..) ;; ; ;; Triang V0.6.5.5 ; ;; ; ;; C:TIN, Generates Delaunay Triangulation and Voronoi Diagram. ; ;; C:CONT, Generates Contours from a sset of 3DFACES. ; ;; C:GEN, Generates a bunch of points for testing. ; ;; C:DEMOZ, Demo of locating yourself in a triangulation. ; ;; C:LBL, Generates Label on Major Contour at regular spacing. ; ;; C:FLBL, Generates Label on All Contours Along Fence Lines. ; ;; C:DLBL, Generates Label Dynamically (Based on Alan JT routine) ; ;; C:PROF, Generates a Longitudinal Profile. ; ;; C:XSHAPE, (Chi-shape) Generates Concave Boundary Around Triangulation ; ;; C:FLIP, Flip Common Edge Between Two Triangles. ; ;; ; ;; Added triloc, ymg August 2013 ; ;; Added getz, ymg August 2013 ; ;; Added demoz, ymg August 2013 ; ;; Modif setup, ymg September 2013 ; ;; Added get_tin, ymg October 2013 ; ;; Added c:flbl, Alan J Thompson October 2013 ; ;; Added c:cont, ymg November 2013 ; ;; Added c:dlbl, ymg November 2013 ; ;; Added c:prof, ymg February 2014 ; ;; Improved contour ymg March 2014 ; ;; Added c:Xshape ymg May 2014 ; ;; Added constraints ymg June 2014 ; ;; Added c:flip ymg July 2014 ; ;; Improved c:prof ymg April 2015 ; ;; Corrected c:Xshape ymg April 2015 ; ;; Updated pos2d ymg April 2015 ; ;; Added get_3dfpts ymg April 2015 ; ;; Added ptinpoly_p ymg May 2015 ; ;; Added tracepline Joe Burke May 2015 ; ;; Modified pos2d ymg May 2015 ; ;; Island Cleanup ymg May 2015 ; ;; Commented ymg May 2015 ; ;; Bug Island Cleanup ymg May 2015 ; ;; Corrected c:prof ymg May 2015 ; ;; Modified c:prof ymg May 2015 ; ;; Mod. getfencesel ymg May 2015 ; ;; Added nicetick ymg May 2015 ; ;; Comments Marko MR May 2015 ; ;; Repl. butlast ymg May 2015 ; ;; Depression Contour ymg June 2015 ; ;; Acceleration Contour ymg June 2015 ; ;; Bug in Contour ymg November 2015 ; ;; Bug in clean-up island ymg November 2015 ; ;; ; (setq version "V0.6.5.5") Quote Link to comment Share on other sites More sharing options...
MillerMG Posted September 23, 2016 Share Posted September 23, 2016 I am fairly certain that you can download a free student version of Civil 3D. Quote Link to comment Share on other sites More sharing options...
