Results 1 to 5 of 5
    Senior Member SAFeSTeR's Avatar
    SAFeSTeR's Computer Details
    W7 64-bit
    Intel Xeon @ 3.20Ghz
    12 GB
    Utilities
    SAFeSTeR's Discipline Details
    CAD Technician
    Utilities
    Water main replacement schemes.
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    Default Polygonal viewport OSNAP 'bug'
    I've had this issue before but never really investigated it further until today.
    I use a lot of polygonal viewports to show twisting routes of water mains along a section of an OS map and add connection details in the remaining paper space areas.
    What I've noticed when using this method is that OSNAPS still snap to the map features in the empty space, however, only within a rectangular area that would fit the extents of the polygonal viewport.
    I'm not looking for a fix as it's not a major issue, but just thought I'd report it and see if anyone else has noticed it and knows why it happens?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,866
    Been like that for a while, AFAIK.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Irregularly shaped viewports are really rectangular viewports that have been clipped (masked). That clipping can be removed, leaving a rectangular viewport.
    Not a bug, just the nature of the beast.
    Drafting is a breeze.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,581
    I generally avoid the non-rectangular viewports. With VPSYNC I find it easy to get the same desired result without the overhead the non-rectangular VP's bring. Your needs may not allow for multiple viewports but that is my work around.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,011
    Robdraw interesting about the clipping, a software developer once told me a trick he used was to make objects same color as screen background so did not see them was faster than going through turning them all off.
  1. Convert Viewport to Polygonal Viewport
    By bapatri in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jan 2015, 04:57 pm
  2. Polygonal Viewport
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 13th Mar 2012, 08:02 am
  3. polygonal viewport
    By bartymic in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2012, 06:39 pm
  4. Polygonal Viewport
    By jowie in forum AutoCAD Beginners' Area
    Last Post: 7th Sep 2008, 07:58 am
  5. Polygonal Viewport -pdf
    By Voogd in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2006, 07:15 pm
Tags for this Thread
