Solid UCS not running Parallel with world UCS
Guitte
Hi Guys,
Im testing out 3D AutoCad's UCS.
Find myself in a bit of a situation. How do you make your Solid model's UCS parallel to the World UCS?
PS: From all the articles i have opened i don't find what im looking for.
Kind Regards,
Guitte
Hi Halam,
I extruded 2 individual poly lines, to create two solids. Somehow the UCS on these objects are different from my WCS. What do i do to make my solid's UCS the same as the WCS?
Thanks.
Maybe..(not sure) ucs of the 3d solid of the created solid has a relationship in what ucs setting the polyline is created. Was the polyline made in wcs? Did you switch to wcs before the extrude command?
May I ask why ucs object of the 3d solid is important in your mode!? Any export involved or something of that kind?
The two typical profiles come from ACad 2D LT. I oped the drawing in ACad 3D, create a new drawing, copy/paste 2 typical profiles which i what to create an assembly with. Somewhere in my attempt of creating a plane on one of the profiles faces and using 3Point UCS on another face. The two profiles did come together, select home and all went "banana" shape.
I started over, if this happens again is there away to fix it?
