Reading .DWG file with vb.NET
DB007
I would like to write a small program that can read all of the pagesetups within a DWG file to check if they have been named correctly. It doesn't need to modify the drawing in anyway.
The program can be standalone or have AutoCAD running but in most cases it will only be LT. Is this possible?
Can I use accoreconsole.exe to read this info?
Thanks
