+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Forum Newbie
    Using
    AutoCAD 2017
    Join Date
    Sep 2016
    Posts
    2
    Default Geometric shape construction assignment help.
    Hello, I need some help on how to proceed with the assignment I'm working on.
    Here's an image of the object I'm currently working on the top one. Or since I can't get it to rotate the left hand side one. I'm confused on how to make the Pill shape at the start point.
    The commands we've learned are Circle, offset, quad, tan, trim all the basic commands and polygons. Pretty much. But most of these according to my instructor can be created only using circles. When theres a 0 with a / through it that means diameter.
    AJOFormrollerlever.dwg
  2. #2
    Super Member halam's Avatar
    Using
    AutoCAD 2017
    Join Date
    Jul 2015
    Posts
    617
    Default
    This indeed is a confusion image.
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  3. #3
    Forum Newbie
    Using
    AutoCAD 2017
    Join Date
    Sep 2016
    Posts
    2
    Default
    I've made some progress since then.
    Here are the attached new ones if anyone could input on how solve the tips on formrollerlever. and how to do the 40 degree angle on geararm I'd be so grateful.
    AJOGearArm.dwg
    AJOFormrollerlever1.dwg
  4. #4
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell OptiPlex 7020
    CPU:
    i7 4790 3.6GHz
    RAM:
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    Graphics:
    AMD Radeon 2GB
    Primary Storage:
    Samsung 480Gb SSD
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2017
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    4,574
    Default
    I can't cover everything here so let me just say a few obvious things you need to know and apply
    Use the tangent osnap
    When you need an arc tangent to two objects you can offset them by the arc's radius, draw the arc from the intersection of the two offsets.
    Watch the image given closer, draw what is explicitly given, add dimensions as you go to verify (use a new layer for dims), draw all center lines, use them to offset, keep those in the drawing.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #5
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,360
    Default
    The forty degree angle starts at the center of the 44 diameter circle. Draw the 40 degree line by starting the line command then typing in the required distance and radius. Example: @100<45
    It is pretty much the same thing for the other drawing. At the centerpoint of the 50 diameter circle start the line command then input the distance and angle. You can then use the Offset command. FYI - Snapang could come in handy too. Angles can be positive or negative. Example of latter: @100<-45
Similar Threads
  1. Construction line vs Regular construction line AutoCAD 2010
    By Sengna in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Mar 2014, 05:36 pm
  2. Draw a Silicone with a Irregular Geometric Shape in CAD
    By User2012 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Jun 2012, 02:06 am
  3. Geometric Construction Problem
    By Laurel in forum AutoCAD General
    Last Post: 6th Aug 2007, 08:23 am
  4. convert close geometric shape into polyline
    By marti in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2007, 04:31 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
