Results 1 to 5 of 5
Thread: Where's the dwt
    Full Member
    not specified
    Feb 2006
    hopewell,nj
    54
    Default Where's the dwt
    In my desktop short my target has the following......
    "C:\Program Files\Autodesk Architectural Desktop 3\acad.exe" /t "tpg.dwt" /p "C:\Program Files\Autodesk Architectural Desktop 3\adt.arg"
    I can't seem to find the tpg.dwt file....anywhere...not on my desktop nor the server.....so where is autocad put the template file....little confused here....does it automatically default to the acad.dwt on my desk top.....or what....
    Company Profile:
    Autocad 2000 ADT 3.3
    Me:
    Autocad 12-2005, Microstation 95-V8, Archicad 8-10, Triforma....and a little bit of other stuff
    Senior Member zars's Avatar
    zars's Computer Details
    Windows Xp Profesional Service Pack 3
    Dell Optiplex 755
    Intel D946GZIS
    Intel Core2Duo 2.13 GHz
    1 GB Kingston DDR2 333 Mhz
    Sata 300 Gb Western Digital
    Dell 17''
    AutoCAD 2007
    May 2006
    LZC, Michoacan, Mexico.
    464
    I don't know where they're located, but have you tried a windows search (searching all files in C) with "*.dwt" it'd throw you all dwt files and there you would be able to see where they are.
    There are only 2 things which are infinite... the universe and the human stupidity.
    "Life is not the amount of breath you take, it's the moments that take your breath away"
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,414
    Open your OPTIONS dialog and click on the "Files" tab. I don't use ADT, but there should be an entry for "Template Settings" or something similar. You should be able to find where your dwt's are located in there.
    Full Member
    not specified
    Feb 2006
    hopewell,nj
    54
    I have done a couple of things....and this why I am puzzled....first ....
    windows is setup to see hidden files and folders....so you would think that under
    C:\Documents and Settings\Username\Application Data\Autodesk\AutoCAD\Recent...there would be a template folder...not here....so I did a wildcard search *.* in the whole Recent folder....nothing...
    C:\Documents and Settings\Username\Local Settings\Application Data....no Autdesk folder
    C:\Documents and Settings\Username\Templates.....no Autodesk folder....
    so I went back to C:\Program Files\Autodesk Architectural Desktop 3\Template and there is no tpg.dwt to be found....
    so I went into Autocad "Options\Files\Drawing Template File Location....nothing there...but 4 autocad files....
    my problem is this....when someone double clicks the autocad icon on their desktop....a file is created with the same layer combinations....which is weighing down the file and then they have to be purged....I am trying to clean this up from the get go....and fix other things with in this mysterious template file
    Company Profile:
    Me:
  5. #5
    Full Member
    not specified
    Feb 2006
    hopewell,nj
    54
    I decided to just make the dwt file...I was curious to what template autocad defaults to if the dwt file it's looking for is missing....thanks for your help
    Company Profile:
    Me:
