Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 54 of 54
  1. #51
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    We place all text and dimensions in the paper space layout. Heights of text/dimensions are set to real world dimensions. It is unnecessary to set the dim scale factor. The only real concern is to make sure all dimensions are associative which is NOT the same as annotative. We've been doing this for quite some time and haven't encountered any problems.
  2. #52
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,595
    Quote Originally Posted by kashbg View Post
    How many of you guys prefer to place dims in Paper Space.
    I am asking because I had a go and encountered a slight inconvenience.
    If I use a particular Non-Anno Dim Style in Paper Space and I have 3 different viewports set at different scales (1:100mm, 1:50mm and 1:10mm), then to actually have the correct Dim Text reading, I would have to select all dims within each vewport and set "Dim scale linear" to 100 for the 1:100 viewport, 50 for the 1:50 viewport and 10 for the 1:10mm viewport.
    Is this how you do it or am I missing something?
    Make sure DIMASSOC is set to 2, sounds like yours is set to 1.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  3. #53
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I much prefer doing annotations in model space for no other reason than convenience.
    Drafting is a breeze.
  4. #54
    Junior Member
    AutoCAD 2017
    Sep 2016
    18
    Quote Originally Posted by rkent View Post
    Thanks "rkent", your were right, my dimassoc was set to 1.
    Problem solved.
    Thanks
  1. SCALE routine to explode and scale dimensions...
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st May 2014, 02:17 am
  2. Dimensions at 1:2 scale
    By beeb in forum AutoCAD Beginners' Area
    Last Post: 8th Dec 2009, 05:45 am
  3. Dimensions/Scale/Help
    By shellb in forum AutoCAD Beginners' Area
    Last Post: 1st Nov 2007, 10:16 pm
  4. scale/dimensions
    By eddie57 in forum AutoCAD Beginners' Area
    Last Post: 27th Dec 2005, 08:15 pm
  5. Dimensions don't scale to Viewport scale
    By brooksn in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jul 2005, 06:18 pm
Tags for this Thread
