Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 59
  1. #11
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    I'm going crazy with this file
  2. #12
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    I would be very grateful if you solve it
  3. #13
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by jim78b View Post
    thanks but i do it all!!!
    Please tell us the steps you've done to try to solve this.
    Is this just the one file or are all files affected?
    Drafting is a breeze.
  4. #14
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    No only One file i post The file
  5. #15
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    I use purge -purge regapps overkill audit Save as dxf ...And purge Nothing
  6. #16
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I was able to speed the drawing up, somewhat, by deleting all blocks named PAL_10P and by deleting 159 block references that mainly appeared as dots (way off in space) named cas_9. I was unsuccessful in my attempts to reduce the file size to any real extent. Audit reported over 240,000 objects and 6158 blocks.
    Looking at a front view of the drawing I found 187 objects that are above/below the bulk of the objects in the drawing. Most are listed as being "dimension disassociated."
    Well it is one of the more interesting drawings I've seen. You have certainly packed a lot of detail into it.
  7. #17
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Is this typical of the files that you usually work on?
    There is a lot of stuff in there.
  8. #18
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    How You Can purge a Lot of things ?The Main problema si when refedit a Block You exit And i must wait a Lot until autocarro regen
  9. #19
    Senior Member
    Mechanical 2013
    Oct 2015
    146
    No It is a file on which i worked
  10. #20
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    What is this file being used for? Is it necessary to have all that stuff in there?
  1. 3AutoCAD file w/ multiple layers big and slow
    By cursedeye in forum AutoCAD General
    Last Post: 31st Jul 2012, 01:56 pm
  2. Certain file slow/not responding
    By ngubk in forum AutoCAD General
    Last Post: 20th Oct 2011, 01:25 pm
  3. File starts fast, gets very slow, very quick.
    By Val Hall in forum AutoCAD General
    Last Post: 4th Jul 2008, 05:19 pm
  4. SLOW file access
    By WagglyFawn in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Mar 2008, 01:38 pm
  5. Slow file browser
    By Big Mike in forum AutoCAD Drawing Management & Output
    Last Post: 9th Dec 2005, 06:53 pm
