Results 1 to 8 of 8
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Default Clipping Boundary on an OLE?
    Hi!
    Is there a way to use a clipping boundary on an OLE from excel?
    I've tried blocking it and then using xclip, but oddly it clips everything _except_ the OLE.
    Basically, I've got multiple tables I want to display throughout the drawing and I'd like them to be linked to a single excel, while still being embedded rather than linked to an external excel file.
    I've been able to use an excel OLE within blocks before to accomplish this for the same table repeated throughout a drawing, but I'm hitting a dead end for doing this with multiple tables.
    Thanks!
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    697
    Put it in a block and clip that.
    maybe..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    I tried that. It doesn't clip the OLE part. At least not using XCLIP.
    AutoCAD 2017
    Jul 2015
    697
    Too bad.
    Why OLE? Image has this advantage and some more..
  5. #5
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    I'm doing this for excel tables that I'll be regularly updating, so a raster image wouldn't work.
  6. #6
    AutoCAD 2017
    Jul 2015
    697
    But why not use the data link technique to link to excel sheet then..?
    ole seems as the most unlogic way
  7. #7
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Using a data link will still be OLE. It would just be convenient and reduce risk of divergent copies if everything were embedded within the drawing file rather than linked from an external excel file.
    But I see where you're coming from. Linking from an external file would be a fix, but not an ideal fix for my situation.
  8. #8
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,567
    I know this introduces ONE MORE STEP - but what we do is print the Excel to PDF, then reference the PDF into ACAD.
    As long as the person who is updating the Excel file remembers to print to PDF, then your ACAD version will be up to date.
    This also has the benefit (over Data Link in post #6), of the data being WYSIWYG.
    R.K. McSwain
    CAD Panacea | twitter
  1. Replies: 4
    Last Post: 25th Dec 2013, 06:07 pm
  2. Viewport Clipping
    By jaredmccullough in forum AutoCAD General
    Last Post: 15th Jul 2013, 10:42 pm
  3. Mark Errors boundary not edge match with adjacent boundary
    By chvnprasad in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Mar 2012, 04:02 pm
  4. clipping dwf?
    By b.muqlueen in forum AutoCAD Drawing Management & Output
    Last Post: 14th Feb 2008, 05:53 pm
  5. Boundary polyline -> Valid Hach Boundary Not Found
    By Jauch-BR in forum AutoCAD Beginners' Area
    Last Post: 23rd Jan 2007, 02:32 pm
Tags for this Thread
