Dynamic Block Rotating Attribute
Hello Gurus:
I am trying to create a dynamic block for section view. However, when I want the section rotates, one attribute does not follow the path while the other doubles the radius of rotation. Please see attached.
Thank you!
ChrisDynamic Block Tester1.dwg
The tag for both attributes were the same I changed them to XUPPER and XLOWER. The tag is the name of the attribute, if you have 2 attributes with the same tag in the same block this confuses AutoCAD just change the tags so they are different. Go to block editor and see what I did. You can change them to whatever you want just as long as they are not the same.
TESTBLOCK.dwg
  • 2 weeks later...
Thanks you guys for your responses. I was away from that task for a few days.
SLW210: I am not sure if it has that feature but Ski_Me's solution works for me.
Ski_Me: Thanks for your help! It works!
