Burner Posted October 6, 2016 Share Posted October 6, 2016 (edited) My annotative dimensions are always being drawn with a 1:1 scale and are not matching the current annotation scale of the drawing. This just randomly started happening. I like to use the "Continue" dimension command, which in this case my start dimension is at a 1/2" = 1'-0" scale. Edit: I restarted the application and my settings reverted back to original.... Edited October 6, 2016 by Burner Problem solved Quote Link to comment Share on other sites More sharing options...
DesmetMartin Posted October 24, 2016 Share Posted October 24, 2016 It could be your 'annoautoscale'. More info here: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-15AC894C-4B21-4543-AD86-F86C8BFAC6E6-htm.html Kind regards, Martin. Quote Link to comment Share on other sites More sharing options...
