Results 1 to 2 of 2
Thread: ATTDEF tags
    Forum Newbie
    AutoCAD 2015
    Oct 2016
    1
    Default ATTDEF tags
    Hello,
    I have a 3D model of a timber frame with many different blocks and I am trying to number each member, so I can see the numbering on each side of a member as I orbit the model. Ideally, an 8 inch square post should have the same number on each of the 4 sides, so I can see the connections with other members, say braces or beams.
    My solution to this was to create a numbering block with an ATTDEF tag that I insert for each frame member. The block should contain 4 copies of the same number and that's where I run into problems. The copies of the same ATTDEF tag requires 4 prompts for the same number.
    So the question is, is there a field corresponding to an ATTDEF tag? How can I define a member number prompt once and have it duplicated 4 times in TEXT or equivalent?
    Thanks
    Andre
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    619
    I saw something similar to what your taking about but for the life of me I can't remember where I saw or read about it. But I think it was a function where you could place a call out tag on each part you made. I think it was a piece of design software that Bombardier was using to develop structural members for it's Lear Jets. Top notch stuff but I only got a glimpse at it. Not sure if AutoCAD can do the same thing maybe inventor is worth looking at.
  1. Add ATTDEF Value to Another ATTDEF Value
    By gnurob in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2012, 09:45 pm
  2. ATTdef
    By PhilMont in forum AutoCAD Beginners' Area
    Last Post: 14th Jun 2010, 09:56 am
  3. attdef , etc
    By drazk911 in forum AutoCAD General
    Last Post: 7th Apr 2010, 08:19 am
  4. Need help with XRef's/ATTDEF
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jun 2006, 11:50 am
  5. ATTDEF/ATTEDIT
    By hankthelank in forum AutoCAD Drawing Management & Output
    Last Post: 11th Nov 2004, 06:32 am
