Results 1 to 6 of 6
    Full Member
    jt6572's Computer Details
    Windows 10
    8GB
    Civil
    jt6572's Discipline Details
    Civil Designer
    Civil
    AutoCAD 2015
    Jul 2015
    Brisbane Australia
    81
    Default Data Link to Excel keeps becoming "unreferenced"
    Hi all,
    i have reffed in spreadsheets for signage schedules (existing and proposed) and have done so so that they can be edited in excel and updated as per a usual x ref.
    i have done it all correctly, however today (did it friday, no issues) it just wont come back in and only ever says it is "unreferenced".
    when i reffed it in (it is two pages in the same excel doc) i made them relative path, and had no issues with "download from source" via Data Link, but today after removing them and trying again due to them not updating, then being not found (the "..\" at the front of the relative path had gone missing) i cant get them in at all now; they simply show up in the x ref manager as "unreferenced" and there is nothing in the drawing.
    i need them to be to a particular format and simply pasting them in is not what i am after as i need for my engineer to be able to update them as well.
    has anyone experienced this and have a solution? would really appreciate any help...
    thank you.
    jeff
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    A datalink does not require a spreadsheet to also be xreffed.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Unreferenced means that the path information is present in the file but the table has been deleted. Using the table command should allow you to reinsert it.
    Drafting is a breeze.
    Full Member
    Windows 10
    8GB
    Civil
    Civil Designer
    Civil
    AutoCAD 2015
    Jul 2015
    Brisbane Australia
    81
    thanks very much guys.
    i honestly cant explain it, but the spreadsheet hasnt been deleted (which is what you would think with it being "unreferenced"). i havent used this function much, so its probably just a noob thing?!
    in any case, it seems fine now, but thank you for the replies.
  5. #5
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by jt6572 View Post
    So, it just fixed itself?
    By definition "unreferenced" means that it is not present in the file. Just the path is.
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Explicitly, "Unreferenced" means the xref or link was attached at one time, and subsequently the inserted image was erased leaving only the still attached path to the file.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. Replies: 21
    Last Post: 14th Jul 2014, 07:04 am
  2. Importing Excel data and draw lines (Data is "From" "To" ponts of Line or length
    By pvsvprasadcivil in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Dec 2013, 10:37 am
  3. Export properties ("measurement") of "Aligned Dimension" to Excel
    By nhatquyelec in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Feb 2013, 07:58 am
  4. Excel Data Link in Civil 3D unreferenced.
    By soozyq in forum Civil 3D & LDD
    Last Post: 22nd Aug 2012, 12:31 am
  5. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
