I wnat to aplay the Photo as a wall paper to a round wall .
Gali
The cropping you see of the image at the foot may be an artifact of the Render Visualstyle. Try rendering the image and see if the cropping is eliminated. It looks like you are using cylindrical mapping which can be a real bear to use. The interactive behavior of visualstyle render may not be the same as what you see when you perform a real render.
Another thing to keep in mind is the aspect ratio of your original image vs. the aspect ratio of the geometry to which you applied the image. This is further complicated by the fact that cylindrical mapping considers the total circumference of the cylinder for scaling purposes. Your circular wall is less than a full circle so you will need to compensate accordingly. Notice how the image on your cylindrical wall is stretched in comparison to the original image. I would suggest turning TILE on and then adjust the scale and position as necessary pushing the image to go just beyond the geometry.
If all else fails you could use planar mapping and accept some image distortion.
~Lee
  • 3 weeks later...
