Results 1 to 9 of 9
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Default AutoCAD Ultra Mobile UI
    I’m hoping to find a couple of AutoCAD users out there that have access to a tablet (Microsoft Surface, . . .), or 2 in 1, or convertible (Lenovo Yoga, . . .). Ideally, this touch capable devise will have a pen which allows for ‘hover’ functionality.
    I’m developing an Add-in UI that tries to compensate for some of AutoCAD’s current mouse and keyboard focus, and allow for more mobile field work.
    See these two screencasts to get a better idea of what I’m proposing:
    https://knowledge.autodesk.com/commu...f-4734419914f9
    https://knowledge.autodesk.com/suppo...df6d68316.html
    I’m fairly close to a beta test release; if anyone is interested, and adventurous, let me know.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,587
    Seant know your work is great but could not the old old screen menu be used for a lot of this ? It was turned off by Autodesk but can be turned back on I found it great predefined info command line or input to lisps.
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    I was a big fan of the screen menu - it was AutoCAD's only Context Sensitive/Morphable interface for many releases. And I think you are right, it probably could be set up in such a way to allow for pen use. Finger use may be tricky, given the relative size of fingers, but that too may be accounted for in a highly customized menu.
    In a way, that's what I'm proposing here; a premade,highly customized, highly specialized menu. It does not bring anything new to the table. The commands are all the same, everything can be accessed in a somewhat familiar fashion - at least for AutoCAD users familiar with the command prompt input. Everything is just spaced differently to facilitate touch and pen.
    I guess if I really did want to be competitive with the Screen Menu I'd have to offer a way to allow individual users an ability to customize the interface, or button commands. Hmm, let me think about that.
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    As a quick rundown on the screen menu for those readers unfamiliar with the interface, see this thread:
    http://forums.autodesk.com/t5/autoca...ht/true#M99181
  5. #5
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Another feature I had considered for the Number Pad tab was to morph the presentation to offer Degrees/Minutes/Seconds input when AutoCAD prompts for angle. Are Degrees/Minutes/Seconds still used in any of the disciplines these days?
  6. #6
    Full Member
    AutoCAD 2005
    Mar 2008
    80
    Quote Originally Posted by SEANT View Post
    Yep they do here.
    P
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,587
    Any one doing survey work still works in DDD.MMSS big hint there, much easier than ddd mm' ss" old HP calculators have a ddd.mmss button. Being able to have a small device for doing infield survey functions would be good.
  8. #8
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    A screencast describing some modifications and new features:
    http://autode.sk/2jivXWk
  9. #9
    Forum Newbie
    Map 3D 2007
    Nov 2008
    8
    Autocad 10?
    (Not from year 2010, back in '80-90. I am old, very old)
  1. AutoCAD WS Mobile 1.4 Available
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 21st Feb 2012, 05:50 am
  2. Autodesk Design Review mobile – DWF files on Apple Mobile Devices
    Last Post: 26th Sep 2011, 04:40 pm
  3. AutoCAD goes Mobile!
    By Lynn Allen's Blog in forum AutoCAD RSS Feeds
    Last Post: 1st Apr 2011, 02:29 am
  4. Ultra Zooming - Display Error?
    By Mk1_Oz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Jul 2010, 06:28 am
  5. Right Click Ultra Customisation
    By wannabe in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Oct 2008, 06:39 pm
