thibles17 Posted October 23, 2016 Share Posted October 23, 2016 I got a problem with my .dwg file while opening AutoCAD - File hangs or crashes AutoCAD. I opened .dwg again and error repeated. I have to recovery dwg file. Any tips, please... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 23, 2016 Share Posted October 23, 2016 Did the recovery fail? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 24, 2016 Share Posted October 24, 2016 Welcome to CADTutor. Some times it can take a while to complete the Recovery process. Did you give the software time to complete the process, and advise as to whether it was successful or not? If not, you probably stopped it mid process. As Rob implies, either it failed, or was not completed. If the Recovery is successful, and completed, you shouldn't encounter another problem the next time you open it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 24, 2016 Share Posted October 24, 2016 Why did you use the word "image" in your thread title? Is there an image attached to the drawing you are having a problem with? If so, did you try detaching the image to see if the problem goes away? Could it be a problem associated with the path to the image? What steps other than trying the RECOVER command have you taken to troubleshoot the problem? Are you experiencing the same problem with other drawings that have an attached image? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted October 24, 2016 Share Posted October 24, 2016 Maybe that particular drawing is corrupt. Does AutoCAD hang or crash with other files? All files? Quote Link to comment Share on other sites More sharing options...
lrm Posted October 24, 2016 Share Posted October 24, 2016 Try starting with a new blank drawing and then use insert to insert the problem drawing as a block at 0,0,0. If this works be sure to explode the block once before proceeding. ~Lee Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 24, 2016 Share Posted October 24, 2016 I would venture that the OP is a spammer, not everyday you find an Electro/Mechanical Dentist. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 25, 2016 Share Posted October 25, 2016 Maybe he specializes in Robotic wisdom tooth extraction? Quote Link to comment Share on other sites More sharing options...
thibles17 Posted October 25, 2016 Author Share Posted October 25, 2016 Yeah, recovery fail Quote Link to comment Share on other sites More sharing options...
thibles17 Posted October 25, 2016 Author Share Posted October 25, 2016 Try starting with a new blank drawing and then use insert to insert the problem drawing as a block at 0,0,0. If this works be sure to explode the block once before proceeding. ~Lee Thank I hope it would assist me. Quote Link to comment Share on other sites More sharing options...
MillerMG Posted October 26, 2016 Share Posted October 26, 2016 If so, did you try detaching the image to see if the problem goes away? Hey ReMark, Quick legitimate question. Hope its not stupid. How would you be able to detach an image if it crashes as soon as it is opened? Quote Link to comment Share on other sites More sharing options...
MillerMG Posted October 26, 2016 Share Posted October 26, 2016 I would venture that the OP is a spammer, not everyday you find an Electro/Mechanical Dentist. Saaayyyy Whatt? Oh man this is a hot occupation right now!! Most employed in the industry have a Willy Wonka's Father (Johnny Depp Version) look with Jason Bourne pizzazz. My dads one! Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 26, 2016 Share Posted October 26, 2016 Cyborgs are electro-mechanical dental patients. Quote Link to comment Share on other sites More sharing options...
