Results 1 to 2 of 2
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    658
    Default import IFC into AutoCAD
    I'm accutaly using Civil3D but i get the feeling the Import / Export function for IFC is the same as in ACA. What i am experiencing is that IFC import will turn solids into mass elements. Is there a simple way to convert these back to solids?
    Or..
    What (dis)advantages has a mass element as to a Solid?
    I'm trying to figure out (better) ways to work with IFC in a AutoCAD enviroment.
    ..O yeah.. btw. How does BricsCAD convert IFC?
    https://knowledge.autodesk.com/suppo...860EC-htm.html
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    AutoCAD 2017
    Jul 2015
    658
    Got it..
    https://knowledge.autodesk.com/suppo...6B00C-htm.html
    only thing is that units get f*ed up with ifcexport..
  1. import from autocad
    By heartache in forum 3D Modelling
    Last Post: 22nd Nov 2012, 06:40 am
  2. Import from AutoCAD
    By Bill Tillman in forum Autodesk Inventor
    Last Post: 15th Aug 2012, 09:05 pm
  3. How do I... Import EPS files to Autocad?
    By maffpunton in forum AutoCAD General
    Last Post: 25th Oct 2010, 04:21 pm
  4. STEP Import for AutoCAD
    By ReMark in forum Catch All
    Last Post: 13th Jan 2009, 04:52 pm
  5. Import fonts into AutoCAD?
    By mine62R in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Mar 2008, 12:25 pm
