Un-dynamic a block - LISP
DesmetMartin
Hello all,
I should get the following code changed so that you can select the blocks you want to 'undynamic" first.
Can somebody help me?
(defun c:UnDynamic
       _get_item
       _right
       _make_key
       _dynamic->static_block
       _get_locked
       _get_dynamic_inserts
       _main
   (defun _get_item ( collection key / item )
       (vl-catch-all-apply
          '(lambda ( ) (setq item (vla-item collection key)))
       item
   (defun _right ( str n / len )
       (if (< n (setq len (strlen str)))
           (substr str (1+ (- len n)))
           str
   (defun _make_key ( collection prefix len / key )
       (   (lambda ( i pad )
               (while
                   (_get_item collection
                       (setq key
                           (strcat prefix
                               (_right
                                   (strcat pad (itoa (setq i (1+ i))))
                                   len
               key
           0
           (   (lambda ( pad )
                   (while (< (strlen pad) len)
                       (setq pad (strcat "0" pad))
                   pad
   (defun _dynamic->static_block ( blocks insert len )
       (vla-ConvertToStaticBlock
           insert
           (_make_key blocks (strcat (vla-get-EffectiveName insert) "_00") len)
   (defun _get_locked ( layers / locked )
       (vlax-for layer layers
           (if (eq :vlax-true (vla-get-lock layer))
               (setq locked (cons layer locked))
       locked
   (defun _get_dynamic_inserts ( blocks / inserts )
       (vlax-for block blocks
           (vlax-for object block
               (if (eq "AcDbBlockReference" (vla-get-objectname object))
                   (if (eq :vlax-true (vla-get-isdynamicblock object))
                       (setq inserts (cons object inserts))
       inserts
   (defun _main ( document / blocks inserts locked len )
       (if
           (setq inserts
               (_get_dynamic_inserts
                   (setq blocks (vla-get-blocks document))
               (foreach layer (setq locked (_get_locked (vla-get-layers document)))
                   (vla-put-lock layer :vlax-false)
               (setq len (strlen (itoa (length inserts))))
               (foreach insert inserts
                   (_dynamic->static_block blocks insert len)
               (foreach layer locked
                   (vla-put-lock layer :vlax-true)
   (_main (vla-get-activedocument (vlax-get-acad-object)))
Credits to TP from theswamp.org.
Thanks,
Martin.
Not so pretty as his, but gets the job done:
(defun C:test ( / ErrCatcher SS i o )
(defun ErrCatcher ( func varLst / rtn ) (if (not (vl-catch-all-error-p (setq rtn (vl-catch-all-apply func varLst)))) rtn))
(prompt "\nSelect blocks to convert them into static ones:" )
(if (setq SS (ssget "_:L" (list (cons 0 "INSERT"))))
	(repeat (setq i (sslength SS))
		(if (eq :vlax-true (vla-get-IsDynamicBlock (setq o (vlax-ename->vla-object (ssname SS (setq i (1- i)))))))
			(ErrCatcher 'vla-ConvertToStaticBlock (list o (vla-get-EffectiveName o)))
);| defun |; (or (vlax-get-acad-object) (vl-load-com)) (princ)
Thanks, it's this kind of thing I want to do.
The only problem is that the name get's changed and you can't edit you static block anymore.
So what I'm trying to say is that the code in the 1st post should be used.
Only thing that should be added in the code is that you select the items you want to undynamic instead of all the blocks.
Thanks,
Martin
@Grrr:
IMO this:
Should be:
(or vlax-get-acad-object (vl-load-com))
Hi Roy,
Yes it seems that it makes more sence:
_$ vlax-get-acad-object
#<SUBR @000000a99c5a6d68 vlax-get-acad-object>
_$ (vlax-get-acad-object)
#<VLA-OBJECT IAcadApplication 00007ff604c59110>
_$
Thanks!
It is not about 'more sense'. I expect that (vlax-get-acad-object) will fail if the VL extensions have not been loaded. I am using the word 'expect' because I am using BricsCAD where (vl-load-com) is a dummy function and VL functions are available by default.
Yes, I mean that I haven't noticed that instead of checking for such function, I'm instead running it with the possibility of triggering an error, such as:
_$ (defun C:test () (strcat 1))
C:TEST
_$ C:test
#<USUBR @000000a99c508570 C:TEST>
_$ (C:test)
_$ (C:test)
Error: bad argument type: stringp 1
_1$
You have sharp eye.
Testing the (vla-ConvertToStaticBlock) function I have noticed something strange (note: as previously mentioned I use BricsCAD).
My test:
1. Insert the same dynamic block twice.
2. Make identical changes to one or more dynamic properties for each insert.
3. The inserts now look the same but reference different anonymous definitions.
4. Copy one of the inserts.
5. The copy references the same anonymous definition as its original.
6. Only convert the copy to a static block.
7. Result: The original of the copy has also become a static block (probably due to what was mentioned under #5).
If AutoCAD has the same behavior, converting only selected inserts to static blocks would require a more complex solution than the code posted in this thread.
This differs in AutoCAD: inserting two references of the same dynamic block and modifying their dynamic parameters to use the same values results in the two blocks referencing the same anonymous definition.
AutoCAD has the same behaviour (as to be expected, based on the above observation).
This is not the case in AutoCAD: converting one of the dynamic block references has no effect on the others.
I've followed the steps Roy mentioned on my Acad 2015, and can comfirm this:
Seems that it adds new block definition, under the provided name:
(vla-ConvertToStaticBlock o "ABC")
But, when I try to convert other block reference under the same / existing block definition name, I get:
_$ (vla-ConvertToStaticBlock o "ABC")
Error: Automation Error. Duplicate key
_1$
But/And It creates an annonymous block definition anyway:
_$ (vla-get-EffectiveName (vlax-ename->vla-object (car (entsel))))
"*U117"
_$
Note that the "Name" property row in the quick properties dialog, always references to the block's "effective name / definition name".
So thats why my previously posted code forces the creation of N annonymous block definitions:
Since this always triggers an error :roll:
_1$
Of course: the block name argument for the ActiveX converttostaticblock method cannot correspond to an existing block, otherwise you will receive a duplicate key error - this is why the original code included the '_make_key' function.
First of all, thanks for all the help so far!
I would like to think together with you guys, but since I can't program, it's though :P
Let me know if you find a solution please!
Thanks!
- Martin
Thanks!
- Martin
Try this:
(defun C:test ( / ErrCatcher BlksColl SS i o cnt flg nm )
; (ErrCatcher 'vla-item (list (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))) "BlockThatDoesNotExist")) -> nil
(setq BlksColl (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))))
				(setq cnt 0) (setq flg 'T)
				(while flg
					(if (not (ErrCatcher 'vla-item (list BlksColl (setq nm (strcat (vla-get-EffectiveName o) "_" (itoa (setq cnt (1+ cnt))))))))
						(progn (vla-ConvertToStaticBlock o nm) (setq flg nil))
					); if
				); while
			); progn
		); if
	); repeat
); if
);| defun |; (or vlax-get-acad-object (vl-load-com)) (princ)
Note that the original dynamic blocks are not purged.
Try this:
				(while flg
					); if
				); while
			); progn
		); if
	); repeat
); if
Super! This is what I was looking for!
Thank you so much!
-Martin
  • 7 years later...
