Changing line space factor for multiple Mtext
bushlake
Hello.
I want to change line space factor for all the mtext objects in a hole bunch of drawings by script.
I found this lisp and it works fine but only by manually selecting the mtext objects.
(setq vla_mtext (vlax-ename->vla-object (setq mymtext (car (entsel)))))
(vla-put-LineSpacingFactor vla_mtext 0.5)
Can this lisp be changed so it changes all mtext objects found in the drawing, or is there another way?
Thanks
(defun C:test ( / acDoc scf cnt )
(setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq scf 0.5)
(setq cnt 0)
(vlax-map-collection (vla-get-Block (vla-get-ActiveLayout acDoc))
	(function
		(lambda (x)
			(and
				(eq (vla-get-ObjectName x) "AcDbMText")
				(eq :vlax-false (vla-get-Lock (vla-item (vla-get-Layers acDoc) (vla-get-Layer x))))
				(vlax-property-available-p x 'LineSpacingFactor)
				(setq cnt (1+ cnt))
				(vla-put-LineSpacingFactor x scf)
(if (> cnt 0)
	(alert (strcat "\nProceeded " (itoa cnt) " mtext objects! "))
	(alert "\nNo mtext objects are found in this tab! ")
);| defun |; (or (vlax-get-acad-object) (vl-load-com)) (princ)
Or maybe just:
(defun C:test ( / scf SS i )
(princ "\nSelect mtexts to change their \"LineSpacingFactor\": ")
(setq scf 0.5)
(if (setq SS (ssget "_:L" (list (cons 0 "MTEXT"))))
	(repeat (setq i (sslength SS))
		(vla-put-LineSpacingFactor (vlax-ename->vla-object (ssname SS (setq i (1- i)))) scf)
(if SS (princ (strcat "\nProceeded " (itoa (sslength SS)) " mtext objects! ")))
Edited by Grrr
Another:
(defun c:mtlsp ( / i s )
   (if (setq s (ssget "_X" '((0 . "MTEXT") (-4 . "<>") (44 . 0.5))))
       (repeat (setq i (sslength s))
           (entmod (append (entget (ssname s (setq i (1- i)))) '((44 . 0.5))))
I can see the next question oh I want a different spacing
(defun c:mtlsp ( / i s rnum)
   (setq rnum (getreal "\nEnter spacing <Cr> = 0.5 "))
   (if (= rnum nil)(setq rnum 0.5))
   (if (setq s (ssget "_X" (list (cons 0 "MTEXT") (cons -4  "<>") (cons 44 rnum))))
           (entmod (append (entget (ssname s (setq i (1- i)))) (list (cons 44 rnum))))
Another:
This code solved the problem perfectly, thanks again!!!
