Results 1 to 4 of 4
    Full Member
    AutoCAD 2017
    Dec 2015
    Aus
    90
    Default centerline command in 2017
    hi all,
    i've switched to 2017 somewhat recently after using running 2011 and found i've been using this centerline command alot. not sure which version of cad it got added to but i'm a fan. i had a lisp routine that i used to do this previously but it would sometimes return a skewed line, so couldn't always rely on it to work properly.
    Anyway, does anyone know if its possible to edit the linetype for the line thats generated when the centerline command is run? at the moment it seems to be set to "center2". I'd like it to just be a continuous line if possible. should be able to specify that somewhere, just unsure where?
    (i tried tricking it by changing linetype scale for center2 linetype to 100 so as to make it look like continuous line but after the centerline command is run it generates the line with linetype scale of 1..)
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    Have you tried to use the system variable “Centerltype” - which sets the line type used in the creation of “Centerlines”.
    Full Member
    AutoCAD 2017
    Dec 2015
    Aus
    90
    Cadtutor to the rescue again.. I love this forum so much! Cheers eldon, that was exactly what i was after
    Senior Member MillerMG's Avatar
    MillerMG's Computer Details
    Windows 7
    OPTIPLEX 3020
    Intel(R) Core(TM) i5-4570 CPU @ 3.30GHz
    8.0 GB
    The two in front of me. Dude, I got Dell's
    Civil
    MillerMG's Discipline Details
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    439
    Quote Originally Posted by masterfal View Post
    Couldn't agree more!!
  1. 2017 - LAYISO Command Settings?
    By MillerMG in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Aug 2016, 07:08 pm
  2. What's New in AutoCAD 2017 – AutoCAD 2017 Preview Guide
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 26th Mar 2016, 12:14 am
  3. How to add a centerline?
    By SFG13 in forum AutoCAD Beginners' Area
    Last Post: 27th Jan 2015, 11:58 am
  4. Bend centerline
    By fakeru in forum Autodesk Inventor
    Last Post: 9th Mar 2010, 05:40 am
  5. trying to add a centerline
    By aieux in forum AutoCAD Beginners' Area
    Last Post: 30th Oct 2008, 02:56 am
