Results 1 to 5 of 5
    Junior Member
    Manufacture
    symysgames's Discipline Details
    cabinet maker, carpenter, building technician, electronic technician, Artist
    Manufacture
    AutoCAD 2000
    Oct 2016
    10
    Default 2D solid surfaces in autocad 2000
    Hello
    I am trying to understand the logic behind the display of 2D solid surfaces in autocad 2000. if you have a same area covered by different 2d surfaces in different layers with different colour which layer or surface hides what surface or layer. Does it depend on the order they are created, does it depend on the colour , is there a method to make one layer cover another. All layers must be on.
    And what about lines that cross these surfaces , some times they show and some times they don't. Is there a logic behind this?
    Thanks in advance for your answers
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Please attach a copy of the drawing you are referring to. An image file is useless; we need a .dwg file.
    Junior Member
    Manufacture
    Manufacture
    AutoCAD 2000
    Oct 2016
    10
    Thank you for you proposition, that won't be necessary ,when I plot the file everything is fine and it I export the file it's ok and when I reload the drawing it's ok it's when I do a regen then I can't always see what I should. Thanks again
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    Perhaps you could investigate the command DRAWORDER.
  5. #5
    Junior Member
    Manufacture
    Manufacture
    AutoCAD 2000
    Oct 2016
    10
    Thank you exactly what I was looking for.
  1. How measure the angle between two surfaces of 3D solid ?
    By AIberto in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Dec 2015, 09:04 pm
  2. Create 3d solid from 3d surfaces
    By joao56777 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Dec 2014, 03:47 pm
  3. Solid fill between surfaces
    By nic6911 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Mar 2013, 06:53 pm
  4. Solid Surfaces
    By NEWMAN1006 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Mar 2012, 02:21 pm
  5. Changing solid surfaces in order to 3d printing
    By nosoutros in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th May 2010, 03:06 pm
Tags for this Thread
