Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
  1. #21
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Quote Originally Posted by halam View Post
    The way one can work with files is something to consider. My wifi was temporary out so my Revit says : failure / abort!
    Not able to save anything anymore, model crash, shuts down program leaving me with a big pile of **** unclear error messsages.
    So maybe TZ, you understand that i may find working offline with smaller models not a bad idea for working moral ..
    I can understand the position on wanting to work on a single file, detached from a "server file", offline. I can also understand the other position, where connectivity is virtually constant, and true collaborative team workflow, and the majority of companies have a demand for multi-user access to a living model. To reprogram the Workshare feature for the 0.0001% of the users who are single-access users, that need to work offline for a very short amount of time because of a hardware issue just isn't in the program's best interest.
    And if you are in fact a single-access user, then don't Workshare the model and problem solved.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  2. #22
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    699
    The reason why i have to work with wifi on a project that is on the network is because, as you may know, rvt can break up huge models into worksets, ONLY if you work with rvt as 'central file'. I never understood the logic why this can't be done with none-central saved file.
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  3. #23
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    You can create a Workshared central model on your local machine. It doesn't have to be on a network at all.
  4. #24
    AutoCAD 2017
    Jul 2015
    699
    thanks for this briljant idea..
  5. #25
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Lol, is this sarcasm, or did you really not know this?
  6. #26
    AutoCAD 2017
    Jul 2015
    699
    Off course I know this. Saving a central file local creates many other difficulties. Probably bigger treats. Forgot to mention the projects are big and with more designers involved
  7. #27
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Not sure why all the sudden you got snippy. Was just trying to assist by throwing out all possible options. I did not mean to offend. Good day.
    -TZ
  1. LAMBDA seems to crap out when stepping through LISP Code
    By Bill Tillman in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2014, 05:20 pm
  2. Stepping through subentity list
    By rj2gregory in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jun 2013, 11:17 pm
  3. Stepping thru selection set for a single attribute multiple times.
    By The Buzzard in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Oct 2010, 01:04 pm
  4. Stepping thru objects in both model & paper space w/ VBA
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jul 2009, 08:33 am
  5. stepping into drawings. . . and back out!
    By comcu in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2008, 03:08 pm
