Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    There's gotta be a system variable that controls this. The problem seems to be too specific for it just to be a corrupt programming. When was the last time the computer your working on had an update?
  2. #12
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Because you have such large files I am suspecting you may have leftovers from a .dgn file, see the following link.
    https://knowledge.autodesk.com/suppo...gn-hotfix.html
    If you have the hotfix installed then follow the instructions for running the application to purge dgn related deleterious.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  3. #13
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by rkent View Post
    +1 That sounds right to me too.
    Starting in 2015 version, if I am not mistaken, Autocad can purge them.
  4. #14
    Forum Newbie
    Architectural
    AutoCAD 2013
    Nov 2016
    7
    I've tried to install this but when I get to the step "Run the DGNPURGE command" I get "unknown command"
    FYI: this is AutoCAD 2013 version 19.0.55.0
    Should I re-boot between installation and execution?
  5. #15
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    There are instructions in the Readme file on how to execute the cleanup tool. Did you run NETLOAD first? There is no mention of rebooting in the instructions.
    Can we get a copy of one of your drawings exhibiting the problem? Upload it to a file sharing website like DropBox then post a link to it here. Thanks.
  6. #16
    Forum Newbie
    Architectural
    AutoCAD 2013
    Nov 2016
    7
    Yes on the NETLOAD, I tried to follow the instructions step by step, and there is no mention for a re-boot. This problem affects all files, no matter how large or small or if they are new or old.
    Maybe I'll try running through these steps a second time.
  7. #17
    Forum Newbie
    Architectural
    AutoCAD 2013
    Nov 2016
    7
    I rebooted, I selected UNBLOCK, and this is the error:
    Cannot load assembly. Error details: System.IO.FileLoadException: Could not load file or assembly 'file:///C:\Program Files\Autodesk\AutoCAD 2013\DgnLsPurge.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
    File name: 'file:///C:\Program Files\Autodesk\AutoCAD 2013\DgnLsPurge.dll' ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
    at System.Reflection.RuntimeAssembly._nLoad(AssemblyN ame fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
    at System.Reflection.RuntimeAssembly.InternalLoadAsse mblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
    at System.Reflection.RuntimeAssembly.InternalLoadAsse mblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
    at System.Reflection.RuntimeAssembly.InternalLoadFrom (String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark)
    at System.Reflection.Assembly.LoadFrom(String assemblyFile)
    at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(Stri ng fileName)
    at loadmgd()
  8. #18
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Is the problem present if you start a new file with one of the AutoCAD templates?
    Drafting is a breeze.
  9. #19
    Forum Newbie
    Architectural
    AutoCAD 2013
    Nov 2016
    7
    Yes it is.
  1. Text not showing proper height in dynamic block and how do I purge unwanted text
    By jaff in forum AutoCAD Drawing Management & Output
    Last Post: 7th Mar 2014, 07:56 pm
  2. No longer able to chage properties of items in palettes
    By JADT in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Aug 2013, 12:31 pm
  3. Help Needed No Longer Able To Get Object Properties And Alter Them
    By Stubby in forum AutoCAD Beginners' Area
    Last Post: 20th Aug 2010, 01:04 am
  4. text tab no longer present in properties toolbar
    By blackwaterdesigner in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Jan 2009, 07:02 pm
  5. Text not showing up on color plots longer than 6'
    By FTWB in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2008, 03:41 pm
