Change unit of scale in texture editor.
xpr0
This is just a guess, I have never used the Texture Editor, didn't even know there was such a thing. :|
Try running the MEASUREMENT command at the commandline, and the current measurement units will be displayed, either by a response of (inches), or (metric).
If you look at the screenshot from SYSVDLG you will see what that system variable setting controls.
It just occurred to me, that this setting might also affect the settings you are asking about.
i checked it. its set to metric .
Maybe contact Autodesk, I have seen tutorials showing them in MM, so I know it can be done.
I believe 2015 was the first with the Texture Editor, Dadgad.
