Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    Civil 3D 2006
    Oct 2006
    16
    Default how can do this at the angle shown
    hello, someoneone recomended me this website, and told me i might beable to get some help on autolisp, my problem is im trying to draw the shape below at the angle shown, can some one show me how it can be done, or can some one give me any web site names, where i might beable to get infor for drawing a shape like the one below at the angle shown ??
    Senior Member
    Architectural DT 2005
    Sep 2006
    334
    Wink
    hi elizabeth...do you want to do this in cad....or as a lisp routine?
    Super Member profcad's Avatar
    profcad's Computer Details
    Windows 7 Ultimate
    Dell
    Dual - Six-Core Xeon
    32GB
    NVIDA GeForce GTX980TI
    DUAL 24" WIDESCREEN
    Education
    profcad's Discipline Details
    Professor Of CAD
    Education
    AutoCAD Revit Inventor Soldiworks
    Revit 2018
    Dec 2005
    Oklahoma City, OK
    857
    We need more information. Do you want to prompt the user for the angle or is it a preset angle?
    John Helton
    Professor of CAD
    Oklahoma City Community College
    Oklahoma City, OK
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    So why not draw it and then rotate it?
    What's going on, is this some homework assignment?
  5. #5
    Junior Member
    Civil 3D 2006
    Oct 2006
    16
    i want to do this in autolisp, using line command e.g comaand"line"; p1 p2 p3 p4 p5, i need to draw it in autolisp exatctly as shown above, need it to pick a center point, and the radius, and to prompt it to draw at the angle thats shown in the pic below
  6. #6
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    Why not use the "polygon" command?
  7. #7
    Junior Member
    Civil 3D 2006
    Oct 2006
    16
    cant do it that way, we must do it in autolisp, becase we also need to add other things to it, like holes etc, i have done that, but i wanna draw the pentagon like shown above, do u know what coomand i can use to draw the pentagon like shown below ?
  8. #8
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    To elizabeth, rebbeca, Tim11,
    Not sure if you are all students in the same class or multiple personalities
    Since in the last lesson you were able to draw the pentagon, you need only a slight revision. Before (some of) you started drawing the pentagon at the top vertex, which is at an angle of 90 degrees (or pi/2). Now you just need to change your starting angle to reflect the counterclockwise rotation of "angle" shown in figure. So you could get the angle from user (with 'getangle'), add that to pi/2 for your starting angle. The angles to the other vertices are as before, 360/5 or 2*pi/5.
  9. #9
    Junior Member
    Civil 3D 2006
    Oct 2006
    16
    thanks its worked :-)
  10. #10
    Junior Member
    Civil 3D 2006
    Oct 2006
    16
    Default hi
    hi the detailed information you just gave inmy post has worked, i was able to rotate the object, do u know how i can u se the offset command ?
  1. 1st angle/3rd angle projection
    By Lazer in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Jun 2011, 02:09 pm
  2. Angle of an arc
    By kanyakumari_t in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jul 2006, 08:50 am
  3. Ends of lines shown as rounded! Help please!
    By gguillory71 in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jun 2006, 08:09 pm
  4. Increase number of shown open drawings in the window menu
    By baddog8it in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jan 2006, 02:26 am
  5. hidden /centre lines not shown in section
    By C.CONSTANTINOU in forum AutoCAD Drawing Management & Output
    Last Post: 17th Aug 2005, 11:33 am
