Results 1 to 2 of 2
    Junior Member
    AutoCAD 2015
    Dec 2008
    14
    Default Page Setup Printable Area Wil Not Change
    I'm using AutoCAD 2015. I received an AutoCAD file in which the paper space has page setup printable area as 24 x 36. I want to change it to another size being 11 x 17. I selected the proper printer for my desirable print size, paper size and orientation. When I ok the dialog box, the printable area remained the same, 24 x 36, it would not change. I tried this in another file that I already have in my computer and the printable area changes with no problems. It's the particular set of files I received from another office in which the printable area remains the same as it came to me, no matter what other page setup sizes I select. Could this be some kind of setting somewhere that the previous user made before it was sent from his office? Is it possible that the printable area can be locked and will not change until it is unlocked? I have never seen this problem before.
    Senior Member
    AutoCAD 2009
    Oct 2012
    316
    Attach file
  1. Printable Area
    By donz67z in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jan 2013, 10:41 am
  2. Printable area for DWG to PDF?
    By byk3bep in forum AutoCAD Drawing Management & Output
    Last Post: 17th Nov 2012, 01:00 pm
  3. Page Setup Resets To Portrait from Landscape in Sheet Set Page Setup Overrides DWT
    By Kapanther in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2010, 12:31 am
  4. about .pc3 and printable area
    By copernico84 in forum AutoCAD Drawing Management & Output
    Last Post: 10th May 2007, 04:03 am
  5. Printable area x paper area
    By fabriciofontolan in forum AutoCAD General
    Last Post: 8th Aug 2003, 06:43 am
Tags for this Thread
