Results 1 to 4 of 4
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    658
    Default Linking DWG's - hatches follow assigned materials
    Hi ,
    I'm getting zero results using objects styles. What i need to have is a way work with linked DWG models in a decent fashion that i can make sections. So hatches should follow the assigned material. This should be possible according to the menu's and what i could find on the internet (2010 ?!) But i'm lost in using complex override mechanisms..
    Please lead the Revit way and show how this can be done properly (and as promised)..
    http://revitclinic.typepad.com/my_we...t-project.html
    Project file
    https://drive.google.com/file/d/0B6-...ew?usp=sharing
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    The workflow that I know of is to create a new Revit model specifically for the use of Linking a 3D DWG. Create an In-Place Generic Model, Link in the file, and click Finish to complete the operation. Now, Link this Revit model into your host model and you can cut no problems. You can assign Cut materials to this in the original Link model, but it'll apply to the entire 3D Solid. So you may be better off using Regions.
    And I believe Revit 2017 has an issue with this approach. It doesn't work from what I know. The developer team changed something and the sting has been felt throughout the Revit community. I do deal with 3D Solids very often so I haven't run into this issue yet in 2017. But 2016 and prior versions, it works just fine.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    AutoCAD 2017
    Jul 2015
    658
    All familiar Tannar. So, how good does cutting solids and displaying patterns with .sat files in 2017 work then? just as fine as DWG solids in <2016? (cynical).. I don't have 2017 to my disposal yet.
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    Quote Originally Posted by halam View Post
    All familiar Tannar. So, how does cutting solids and displaying patterns with .sat files in 2017? Probably just as fine as DWG solids in <2016? (cynical) I don't have 2017 to my disposal yet.
    I do not know if .SAT files will stay native. I believe they can be converted directly to native Revit geometry. Have you tried this yet? I think there's either an Import option, or you simply Explode once the .SAT file has been imported.
  1. How to edit these hatched areas
    By Quik&Easy in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Aug 2014, 02:02 am
  2. Linking to excel vs linking to parameters in part file
    By czc in forum Autodesk Inventor
    Last Post: 26th Nov 2013, 01:23 pm
  3. Sum of Hatched Areas
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2010, 01:38 pm
  4. Trimming hatched areas
    By matt4 in forum AutoCAD Beginners' Area
    Last Post: 22nd Apr 2009, 04:33 pm
  5. Altering Hatched Text
    By hyposmurf in forum AutoCAD General
    Last Post: 22nd Mar 2003, 10:02 pm
