Results 1 to 6 of 6
    Full Member
    AutoCAD 2014
    Nov 2014
    34
    Default Extrude, Extrude Faces, Union
    Hello,
    I need some help. please see the document attached, and i need to join all triangules, and than extrude untill the rectangle.
    I tried to do but, dont create a solid. What im doing wrong. Could you help me
    hioohio.dwg
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,845
    Were you intending to extrude all the triangles in the same or different directions? What height did you plan on using? Would it be the same for all three triangles or different? Extruding each triangle does yield a 3D solid to begin with. What did you do different?
    I extruded all three triangles in the same direction 50mm. This is what I got as a result as seen via the four standard isometric views.
    Full Member
    AutoCAD 2014
    Nov 2014
    34
    Attachment 59914
    What i want is to extrude, to made a Union, to make one solid, and then make the mass properties and achieve the Volume.
    The extrude must be done with the extrude (path) to make the extrude in the "Z". My issue is, i can not make a solid because when i made the union, autocad dont let me done this.
    I've tried too, with a solid, and the with UCS, and slices cut a big block, with the shape of 3 triangules.
    The lengh of extrude is 15. I dont know why the autocad dont let me UNION the three extruded triangles. The gap between 3 triangles, must be cover.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,845
    All I did was reorient the UCS then I ran the EXTRUDE command to obtain what you see above. I did not have to specify a path of any kind. I'm sure if I went back I could union all three triangles I created too but that would obviously not make up for any gaps between triangles.
    What do the three triangles represent? What are you attempting to create?
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,845
    joao: Did you solve your problem?
  6. #6
    Senior Member
    AutoCAD 2017
    Jul 2011
    103
    I am not sure if this relates to the problem but the 3 triangles are done in 3 different UCS plane - when extruding each triangle 15 unit, they extrude perpendicular to the USC they were placed / made (just like what ReMark is showing)
    Extruding each triangle in different direction shouldn't stop you from using union command and make one solid
    If you want no gap between the triangles then use same UCS to draw all 3 triangles
    Hope that helps
  1. How to extrude this faces?
    By prime333 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Jun 2015, 02:21 am
  2. Extrude / Taper Faces
    By MinaRAI in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Sep 2014, 08:56 am
  3. cannot extrude into solid but gives me surface extrude
    By amard_burn in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Nov 2013, 05:31 am
  4. Extrude faces on a solid
    By Orbit in forum AutoCAD General
    Last Post: 23rd Jun 2003, 04:56 pm
  5. Extrude & Extrude faces
    Last Post: 21st Dec 2002, 07:21 pm
