gegenytibor Posted November 29, 2016 Share Posted November 29, 2016 Hello, I created a dynamic block with arrows and an attriboute text. I had to use multiline text because I need background. When I rotate the block the text is not in the good direction on the left side (the other three way is ok). Is it a way to orient to the readable way the attriboute text somehow in the rotated block? Thanks for the answers! TB arrow.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 30, 2016 Share Posted November 30, 2016 Yes, I posted a question some time ago and some dynamic block solutions were offered, my question was answered in a different way. Try search BIGAL dynamic block etc I will try to find. Try this first using annotative text. Quote Link to comment Share on other sites More sharing options...
gegenytibor Posted November 30, 2016 Author Share Posted November 30, 2016 Hello BIGAL, Thank you for your answer! Where can I found this settings? Is it working with attriboute as well? If I use att command I ahave this settings only: Quote Link to comment Share on other sites More sharing options...
