+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Full Member
    Computer Details
    jiggly_jelloo's Computer Details
    Operating System:
    Windows 7 Professional 64 Bit
    CPU:
    Intel i7-3820 @ 3.60GHz
    RAM:
    32 GB
    Graphics:
    ATI FirePro N3800
    Monitor:
    Samsung SyncMaster T220 (Dual Monitors)
    Discipline
    Architectural
    Using
    AutoCAD 2009
    Join Date
    Jan 2013
    Location
    Edmonton, Canada
    Posts
    84
    Default Annotation of multiple details in model and paperspace....looking for opinions
    I do not work a lot in autocad (we run autocad 2009), but my boss wants me to create a drawing that contains all of our standard details (close to 200). These details vary in size from being 2" x 2" all the way up to 12' x 60'. I have created a grid in MS, then I have created layouts with 24 view ports so that he can use these as an 'index'. I then have an individual layout for each detail that can be printed for manufacturing.
    Some of the details are already existing in other autocad drawings, so they are simple to cut and paste out, but we also use solidworks so I have been saving those details as .dwg files, but there are a lot of formatting issues to deal with.
    The issue I am having is with annotating and dimensioning and scale. I think that the simplest way would be to dimension and annotate in paperspace, but I would have to do everything twice, once on his index sheets then once on the detail sheets. And if he wanted to look at something in model space (which he quite often does) there would be no annotations there.
    I have been reading up on annotative dimensions and this seems a possible solution but I am not sure how well it will work with so many different drawing scales required.
    Any suggestions would be appreciated!
    Colleen
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,879
    Default
    How many different scales are we talking about?
    How do you plan on grouping the 200 details that you have?
    You're right. Using annotative scaling for all text and dimensions would avoid the hassle of reproducing the same in model space and in the layout.
  3. #3
    Luminous Being RobDraw's Avatar
    Using
    MEP 2017
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    5,179
    Default
    What kind of details are we talking about? It sounds like a mess to me without any context.
    Drafting is a breeze.
  4. #4
    Full Member
    Computer Details
    Operating System:
    CPU:
    RAM:
    32 GB
    Graphics:
    ATI FirePro N3800
    Monitor:
    Discipline
    Architectural
    Using
    AutoCAD 2009
    Join Date
    Jan 2013
    Location
    Edmonton, Canada
    Posts
    84
    Default
    It is a mess. It is not in any way, shape or form how I would do things, but he is the boss and what he wants he will get.
    We manufacture relocatable structures (office trailers, portable laboratories, accomodation units....both on metal skids and wheeled units). So there are a lot of items that are standard so making individual detail sheets so that I don't have to redraw with each and every job would increase efficiency. Things like sheet metal drain pans, metal racking and steel piece parts that are used in the skid and chassis, 12v wiring diagrams, electrical diagrams, decal locations and all sorts of other stuff. I did have everything set up as individual details, then an excel index that had some additional columns set up for type of detail etc, so it could easily be sorted, then I had hyperlinks to the individual details so it was quick and easy to find things. We are a very small company so we don't have a pdm tool to keep things organized, so this was the simpliest way I could deal with it!
  5. #5
    Super Member
    Computer Details
    Ski_Me's Computer Details
    Computer:
    DELL (why oh lord must I suffer)
    Discipline
    Electrical
    Ski_Me's Discipline Details
    Occupation
    Fire Alarm tech
    Discipline
    Electrical
    Using
    AutoCAD 2018
    Join Date
    Apr 2012
    Location
    Edmond. OK
    Posts
    643
    Default
    OK so 200 details are a lot but I'm you could use maybe 4 to 5 different scales to cover everything you got. Since you already have your layouts created assign your annotation scale to each layout. Just be sure you assign the annotation scale to each object which can be as many as you like. For instance you can assign a 4:1 scale and a 8:1 scale to your object and select which scale you want to be visible in model space. It will take some work to get things set up but once your done it will be a lot easier. There is a bit of a learning curve to manage your annotative scales but once you have it figured out you'll find they can be very helpful.
  6. #6
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,715
    Default
    Sounds like you should start with Palettes or my old fashioned and create some menus with groups of common items these can have sub sub menus' etc with some task behind the pick button. If you can use notepad you can create menu's.
  7. #7
    Senior Member
    Using
    AutoCAD 2009
    Join Date
    Oct 2012
    Posts
    342
    Default
    I agree with BIGAL
    It is better to make 1 element = 1 file.
    Select and insert the item in the drawing.
    I have since 2700 organized elements.
Similar Threads
  1. Automation for multiple details in viewports
    By Fett2oo5 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jan 2016, 02:39 pm
  2. Replies: 0
    Last Post: 16th Sep 2010, 10:20 am
  3. Annotation multiple scales
    By The seeker in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Jan 2010, 01:29 pm
  4. Delete multiple annotation scales in one viewport?
    By venuj99 in forum AutoCAD General
    Last Post: 22nd May 2009, 01:33 pm
  5. How to clip details or callouts from multiple Xref dwg?
    By Cadkiller in forum AutoCAD Drawing Management & Output
    Last Post: 9th Apr 2006, 10:17 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
