Results 1 to 1 of 1
    Junior Member
    Civil
    bijoymano's Discipline Details
    Lead CAD Designer
    Civil
    AutoCAD 2010
    Jun 2010
    20
    Default Field based Attribute blocks value showing wrong if we attach as xref
    Field based Attribute blocks value showing wrong when we attach as xref.
    it is an coordinate block in main file it is showing properly eg 20536.123,54625.123 but when I trying to attach that file to my cut sheets coordinate value showing 000,000. please let me know how to solve this issue
  1. What's wrong with this attach code
    By mit in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Nov 2016, 05:29 pm
  2. XREF completely wrong coordinates and wrong scales
    By cat3appr in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Aug 2016, 01:43 pm
  3. Batch hyperlinking based on attribute names in blocks
    By ahazen in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2015, 06:14 pm
  4. Block's name to FIELD (based on existing lisp)
    By tomjas in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jan 2015, 05:54 am
  5. Dynamic blocks not showing enhanced attribute editor
    By P Zero in forum AutoCAD General
    Last Post: 25th Oct 2007, 03:11 pm
