Results 1 to 2 of 2
    Forum Newbie
    Mechanical
    AutoCAD 2015
    Nov 2016
    1
    Default Data Extraction and Blocks
    I currently have blocks with attributes for valves and within the blocks, it calls out a mounting plate and fitting. These blocks gets inserted into a design layout and once its completed, a data extraction is ran to create a bill of material pulling the part numbers from the blocks.
    I would like to add different types of mounting hardware to the valve block so that the engineer can turn on the required layers and have that hardware data extract with the data extraction.
    I tried this but even if the hardware layer is turned off, the data still gets extracted in the data extraction. Is there a way to do this?
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    You may have to write a custom data extraction using lisp etc to filter down the required output.
  1. Pallettes, blocks and data extraction
    By MisterJingles in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jun 2012, 09:55 am
  2. Dynamic Blocks & Data Extraction
    By CADadam in forum AutoCAD Drawing Management & Output
    Last Post: 12th May 2012, 02:30 pm
  3. Data Extraction Nested Blocks
    By mrthra in forum AutoCAD Drawing Management & Output
    Last Post: 17th Apr 2012, 11:21 am
  4. Data Extraction for cutlist based on dynamic blocks
    By primalscr33m in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jun 2011, 05:10 am
  5. Dynamic Blocks and Data Extraction
    By SuperCAD in forum AutoCAD Drawing Management & Output
    Last Post: 16th Aug 2010, 12:26 pm
