Results 1 to 10 of 10
    Junior Member
    AutoCAD 2017
    Sep 2016
    18
    Default How to shrinkwrap objects with Polyline?
    I have a floor layout drawing detailing multiple rooms that have been already polylined for area calculation.
    Is is possible to select the polylines of 6 or 7 rooms and create new polyline outlining the area of rooms.
    This may be also refereed as Shrinkwrap or ...
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    There is no "Shrinkwrap" command in AutoCAD.
    I think you can accomplish what you want via the BOUNDARY command and a little bit of creative thinking. Someone asked a similar type question (creating an outline of a group of irregular shaped hatches) earlier this week. I'll see if I can locate the thread.
    OK....a link to thread. http://www.cadtutor.net/forum/showth...light=boundary
    My solution can be seen in post #8.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    There is a Shrinkwrap command for AutoCAD Architecture. Is this what you mean by "Shrinkwrap"? See here:
    https://knowledge.autodesk.com/suppo...47D25-htm.html
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Junior Member
    AutoCAD 2017
    Sep 2016
    18
    Hi ReMark,
    Thanks for your help.
    I had a go with the described by you method but it appears it only works on objects that are physically touching or overlapping each other.
    I am attaching a dwg that best describes what I am trying to achieve.
    There are multiple rooms polylined individually, converted to an individual block (not sure why) with area attributes. I would like to find out if I can select lets say 7 or 8 or the rooms and create one new polyline, outlining everything. In other words the new polyline would mark the Department boudary. The problem here is that the single room polylines are not touching each other neither overlap.
    Any ideas?
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Yep, there has to be a monkey wrench in every problem. While my idea would work (with a slight tweak) in some areas in others it wouldn't work at all. I'm stumped.
    I believe I found what you are looking for. But I have not tested it on your particular problem. Funny though as I'm sure I checked Lee Mac's website when I was attempting to help out in the other thread I linked to above.
    OK....What you need to do is jump on over to Lee Mac's website and download/test his Outline Objects lisp routine. This is a link to his website. Note that in the program description he specifically mentions the word "shrinkwrap". How I missed this program before I have no idea. I hope it solves your problem. Report back with the result as I would be most interested in hearing. Good luck.
    http://www.lee-mac.com/outlineobjects.html
  6. #6
    Junior Member
    AutoCAD 2017
    Sep 2016
    18
    Thanks ReMark,
    I will try your remedy and report back.
    Lee Mac's website keeps comming up regulary and indeed it is extremely usefull to all cad operators.
    Thanks for your assistance.
  7. #7
    Junior Member
    AutoCAD 2017
    Sep 2016
    18
    Sorry ReMark,
    It did not work.
    This is no different to the boundary command. It outlines individual rooms/ closed polylines but not the total area.
    Any other sugestions?
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Yes. One. Download and install the 30-day trial version of AutoCAD Architecture. Of course this would assume that the Shrinkwrap command in the program would work given your special circumstances. The only other idea that comes to mind would be to hire a lisp guru to write a program specific to your needs. This is not something I see someone doing free of charge.
  9. #9
    Junior Member
    AutoCAD 2017
    Sep 2016
    18
    Right,
    I guess there is no fix yet that anybody has needed.
    This drawing (attached) is produced by professional surveyor company. The area surveyed had been polylined and cataloged as per individual rooms/ polylines.
    Can anybody fugure out how they created the polylines (other than physically tracing) and why would they convert to individual blocks with attributes.
    There has got to be an easy way to automate this or method of doing this quickly. Has anybody come accross such work and if so can anybody describe to me the process of doing it.
    Thanks
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Instead of wishing and hoping for an easy solution you should start looking into the two options I suggested previously unless time is of no concern.
  1. Tough Questions - Closed Polyline Tool (Shrinkwrap) Lisp
    By johnshar123xx in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Feb 2017, 11:29 pm
  2. Multi-Leader Shrinkwrap
    By Shoey in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th May 2016, 05:53 pm
  3. Objects besides polyline. Please Help
    By aaryan in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Jul 2012, 10:09 am
  4. Shrinkwrap - Can you do without it?
    By spittle in forum MEP
    Last Post: 20th Apr 2011, 07:55 am
  5. Shrinkwrap using iLogic.
    By GatorDanner in forum Autodesk Inventor
    Last Post: 3rd Jan 2011, 04:45 pm
