jjatho Posted December 5, 2016 Share Posted December 5, 2016 I've uploaded an example of what I'm trying to do to Dropbox since it was too large to attach: https://www.dropbox.com/s/6q82ruf5f9la5xf/Derrick%20Example.dwg?dl=0 Long story short, the object in the drawing is the elevation view of a component of a crane, known as a derrick. I would like to be able to create a rotation parameter, centered on (0,0), that would allow me to rotate the derrick from the postion on the left to the position on the right. The catch is, I would want all of the objects in magenta to not rotate. Obviously this would be easy for the crosshair at the base, as I could simply not select the two lines when setting the objects for the rotation parameter. The hard part will be the crosshair and text at the tip of the derrick. I'd want them to move with the point they are at, but not rotate. Basically keeping the same orientation in the drawing. Any one have any ideas? Is this even possible? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 6, 2016 Share Posted December 6, 2016 Have you tried constraints? I can't access dropbox, can you post an image or strip the drawing down and repost? Quote Link to comment Share on other sites More sharing options...
jjatho Posted December 6, 2016 Author Share Posted December 6, 2016 Derrick Example.dwg I was able to reduce the filesize a bit. I'm working on figuring out constraints right now, though they aren't giving me the result I'm looking for. Quote Link to comment Share on other sites More sharing options...
maratovich Posted December 6, 2016 Share Posted December 6, 2016 Done. Example: Crane.dwg Quote Link to comment Share on other sites More sharing options...
jjatho Posted December 6, 2016 Author Share Posted December 6, 2016 Perfect, thank you! Quote Link to comment Share on other sites More sharing options...
jjatho Posted December 12, 2016 Author Share Posted December 12, 2016 Pivot Section.dwg I've had some success, as the file here works properly if I use the rotation parameter, but I find that using the ROTATE command on this same block screws it all up. I'm guessing that there's no way to have both the rotation parameter and the ROTATE command produce the same effect as far as the objects in magenta staying aligned to the X axis? Quote Link to comment Share on other sites More sharing options...
maratovich Posted December 13, 2016 Share Posted December 13, 2016 as it should? Quote Link to comment Share on other sites More sharing options...
