Lawrst Posted December 5, 2016 Share Posted December 5, 2016 Other than using Fieldeval, is there a way I can stop a field from updating? So for an example. I wanted to build a drawing set and have a field looking at a filename. Once the drawings are finished and the dwg has been sent to a customer (once it is an 'as built') I want the fields to remain the same, regardless of the location the file has been put. Is this possible? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 6, 2016 Share Posted December 6, 2016 Answered here: http://www.cadtutor.net/forum/showthread.php?38027-Can-you-convert-FIELDS-to-Text Quote Link to comment Share on other sites More sharing options...
Lawrst Posted December 6, 2016 Author Share Posted December 6, 2016 Thanks, I knew about exploding the text. But alot of my stuff has been setup in blocks. Its quite a tedious process to convert all those fields to text over 100s of drawings. Negating any benifits of the fields. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 6, 2016 Share Posted December 6, 2016 Welp, that is a horse of a different color than your OP, isn't it? I'm sure it could be batch processed with some creative coding. Quote Link to comment Share on other sites More sharing options...
Lawrst Posted December 6, 2016 Author Share Posted December 6, 2016 Well it depends on the output, i was just trying to give a basic example. We do drawing sets of electrical Schematics for large control systems. I'm currently prepping for a repetitive job of over 500 sheets and fields will be quite prevalent. So your solution wouldn't work, if i had been doing 5-10 drawings it would be have been workable. I think batching the system variable might be the best option. Unfortunately my company only has LT, so I'm limited to third party options that use a batch from the command line. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 6, 2016 Share Posted December 6, 2016 Basic examples get basic answers. Sorry to waste your time. Quote Link to comment Share on other sites More sharing options...
Lawrst Posted December 6, 2016 Author Share Posted December 6, 2016 Don't apologize, I thank you for your input. Quote Link to comment Share on other sites More sharing options...
tombu Posted December 6, 2016 Share Posted December 6, 2016 Very strange request, we have a field referencing the file name and location in the title block of all our drawings so anyone who plots it out can always find it at a later date from the plot. I'd like anyone the drawing is shared with to have the same advantage. Quote Link to comment Share on other sites More sharing options...
Lawrst Posted December 8, 2016 Author Share Posted December 8, 2016 I agree that is a useful application, but its not required with our drawings. I would like to use that for other purposes, but will see how we go. Quote Link to comment Share on other sites More sharing options...
