Fillet??
mattador04
In AutoCAD, i am used to being able to place a "semicircle" shaped fillet between two lines that are PARALLEL, and it automatically figures the radius. Does Inventor have the same functionality?? In this view, I am in a sketch with parallel lines, and I have the fillet command active. Fillet Question 2.jpg Whats going on here??
Start a new line at the end of one of your lines. Left click and hold the button down while dragging the mouse to the lower lines end point. It will draw a half circle from point to point.
https://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/2014/ENU/Inventor/files/GUID-98970816-0791-4AAF-9C71-3400E90358C1-htm.html
