Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    AutoCAD 2010
    Apr 2011
    76
    Default CUI - Mouse Button modify
    Hi, I would like to know if there is a macro for Shortcut Menu? I would like to modify Button 3 (Transparent Orbit as of now) to be my Shortcut Menu. I use Mouse 2 as my Enter button so it is unchecked in the User Preferences. Thanks in advance.
    AutoCAD 2013
    Nov 2011
    5,995
    If you are unfamiliar with it, you might want to check out time-sensitive right-click.
    It enables you to combine the ENTER command, and or, access the Shortcut menu easily on the fly.
    Full Member
    AutoCAD 2010
    Apr 2011
    76
    Over the years I got used to using the right click button for ENTER. But I would like to modify the CUI to see if I can modify the Mouse Buttons>Button 3 to be the Shortcut menus like when you Right click a wall and it gives you the options to Edit wall style, or Edit object display, etc. ... I tried to attach a picture here but it won't let me do it
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    761
    Quote Originally Posted by Dj_T_Rex2002 View Post
    CUI → Mouse Buttons
    Click
    Shift+Click
    Ctrl+Click
    Ctrl+Shift+Click
  5. #5
    Full Member
    AutoCAD 2010
    Apr 2011
    76
    Unhappy Doesn't work for me
    Quote Originally Posted by Dadgad View Post
    I did what you showed in the pic but it only drags the object rather than displaying the menu
  6. #6
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    761
    Quick click for Enter and slightly longer click for the menu. You can set the delay in milliseconds. Don't drag the mouse! They added it as a feature to move objects, but not many care for it.
  7. #7
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    761
    2nd that! I've had it on since it was introduced.
  8. #8
    Full Member
    AutoCAD 2010
    Apr 2011
    76
    Default Ok I see the confusion
    Ok what I am trying to do is bring the object selected right click option. If you set the "Right-Click Customization" to Shortcut Menu on all, then select a wall and right click it bring an option to be able to modify that wall. That's why I said that it drags cause I select the object and then hold right click and does nothing. I want to bring that object's menu ... wish I could insert a picture but every time I hit the "upload file" it doesn't do it
  9. #9
    Super Member
    Windows 7 64-bit
    Dell
    Civil
    Design Analyst
    Civil
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    761
    As long as "Shortcut menus in drawing area" and "Turn on time-sensitive right-click" are checked they should function fine. You can add Shortcut Menus, but they are for an AutoCAD object like Line, Arc, or LWPline. There are also Shortcut Menus for multiples of the same object as well since many options for multiple objects are different than you have for a single one.
    Is the "wall" you mentioned a line, polyline or some other object?
  10. #10
    Full Member
    AutoCAD 2010
    Apr 2011
    76
    I use AutoCAD Architecture 2015 so it's a wall... I guess it's a 3D wall
  1. Edit Text button on the Modify II toolbar
    By Numerics in forum AutoCAD Beginners' Area
    Last Post: 28th Apr 2010, 02:19 am
  2. Which mouse button is which ?!
    By Emile in forum AutoCAD Beginners' Area
    Last Post: 13th Feb 2009, 02:44 pm
  3. 4 Button Mouse Set-up
    By titan1122 in forum Hardware & Operating Systems
    Last Post: 22nd Jul 2008, 04:50 pm
  4. Setting middle mouse button as F3 button
    By alerch in forum AutoCAD Drawing Management & Output
    Last Post: 1st Aug 2006, 10:04 pm
  5. Right Mouse Button
    By Blondie in forum AutoCAD Beginners' Area
    Last Post: 2nd May 2006, 01:58 pm
