DIESEL function within ribbon button, highlight buttons
Aftertouch
Hello all,
I have build my own ribbon, but i experience a problem.
I have a button in my ribbon that shows the text:
STATUS: $(substr,$(getvar,USERS1),1,1)
When i start a drawing, the ribbon updates to the text as it should.
BUT...
When i change the value of USERS1, it does not change in the ribbon.... how can i solve this???
I want that text to by dynamic to the USERS1.
also...
Is it possible to let a buton look 'pressed' depending on a variable?
Like... when filedia = 1 i want a button to look 'pressed/highlighted' and when its 0 it looks regular.
Does not work.
The only thing that works is when i do WSCURRENT. then it 'reload' everything with the right settings.
But due to our drawingsystem, this variable can change a few times per minute, so i want it to by dynamic. :-)
In my experience with DIESEL and Macros, there is a delay from setting a variable to it being available for use. For example if you set a variable in a macro and attempt to use it in that same macro, it will not use the new value, but the old value.
I'd expect that the issue you are experiencing is the same.
Great work with the DIESEL though, that is a great idea of pushing the boundaries! I hope you can get something to work.
Besides Modemacro which I've used for many years I added a flyout to the "Object Snap Cursor Menu" Shortcut Menu named
$(eval,OSNAP = $(if,$(and,16384,$(getvar,osmode)),"Off","On"))
that has a lot of macros that toggle system variables that update their display automatically. I was never able to do the same in the Ribbon.
This one displays whether or not you can snap to Hatch objects:
Display Name:
$(if,$(and,1,$(getvar,osnaphatch)),!.)Hatch
Command Name: Hatch
Description: Snap to Hatch Objects
Macro:
^P'setvar;osoptions;$M=$(if,$(and,1,$(getvar,osoptions)),$(-,$(getvar,osoptions),1),$(+,$(getvar,osoptions),1)) ^P
HTH
