Copy to Clipboard
satishrajdev
Hi,
I'm trying to send string to clipboard using following function but its not working for me. I have searched for other functions but finding the same function of MP's everywhere.
http://www.cadtutor.net/forum/showthread.php?80784-Need-Lisp-code-for-pick-the-text-in-drawing-and-save-in-clipboard
http://www.theswamp.org/index.php?topic=21764.msg263322#msg263322
Kindly help me out of this.
Regards,
Satish.
(defun _SetClipBoardText (text / htmlfile result)
 ;;  Caller's sole responsibility is to pass a
 ;;  text string. Anything else? Pie in face.
 ;;  Attribution: Reformatted version of
 ;;  post by XShrimp at theswamp.org.
 ;;  See http://tinyurl.com/2ngf4r.
 (setq	result
 (vlax-invoke
   (vlax-get
     (vlax-get
       (setq htmlfile (vlax-create-object "htmlfile"))
       'ParentWindow
     'ClipBoardData
   'SetData
   "Text"
   text
 (vlax-release-object htmlfile)
 text
do you have (vl-load-com) installed/loaded ?
Yes. I have done that in my main code
@satishrajdev:
If Steve's comment does not help:
How do you determine that it does not work, is there an error message?
It just returns "" and if I check from cntl+V it doesn't matches.
From the return value I conclude that you are using the function like this?:
(_SETCLIPBOARDTEXT "")
Do you want to clear all clipboard data?:
(defun _ClearClipBoard ( / htmlfile)
 (vlax-invoke
   (vlax-get
     (vlax-get
       'ParentWindow
     'ClipBoardData
   'ClearData
 T
Hi,
Regards,
Satish.
Tested with Windows 7 64bit
Command: (_SETCLIPBOARDTEXT "Cool!")
"Cool!"
It pasted fine in a document.
What version of Windows are you using?
ttechnik's post: https://www.theswamp.org/index.php?topic=21764.msg541448#msg541448
he code is correct. In W2k....
But in W8 not work.
I'm guessing that the command y'all are trying to use is not valid in older Acad versions !!
It won't work in AC2008 for example.
what version of AC is the OP using ???
if setdata failed, would getdata failed too?
catch exception?
(defun cdata (/ cb html)
 (if (vl-catch-all-error-p
(setq cb (vl-catch-all-apply
	   'vlax-invoke
	   (list (
		  '((doc)
		    (foreach x '(parentwindow clipboarddata)
		      (if (not (vl-catch-all-error-p (setq doc (vl-catch-all-apply 'vlax-get (list doc x)))))
			doc
		   (setq html (vlax-create-object "htmlfile"))
		 'getdata
		 "text"
   cb
running in vbscript, see any error?
copy this code in notepad then save as "cp.vbs"
This vbs source but no longer exists :(
Set objHTML = CreateObject("htmlfile")
ClipboardText = objHTML.ParentWindow.ClipboardData.GetData("text")
MsgBox ClipboardText
example saved in D directory
locate & double click the saved "cp.vbs" file to run
or you cand invoke using lisp
(command "shell" "cscript D:\\cp.vbs")
;or
(command "shell" "explorer \"D:\\cp.vbs\"")
Try searching msdn documentations many good resources
Often programs will put several versions of copied data on the clipboard. Only changing the text on the clipboard will *not* remove the other data. This may be the root of the OP's confusion.
So a more reliable version of _SETCLIPBOARDTEXT would clear all data first (see my previous post).
You are right, If I do this it returns string
After that when I do ctrl+V I don't get "Sat123" text and that's my main concern.
_$ (_SETCLIPBOARDTEXT "Sat123")
"Sat123"
"Cool!"
When I do ctrl+V after the expression I don't get "Cool!"
But in W8 not work.
I'm Using Windows 7 64bit.
I'm aware about that, But I'm using AutoCAD 2013. and We have AutoCAD 2014 to 2016 as well. I tried in all version but no luck.
