Room Dimensioning Lisp requesting
structo
Hi All Friends,
i need one lisp for auto room dimensions by following rules:
1)select first top left corner point of the room
2)select bottom right corner point of the room
3)choose room description text from list
a) choose different options from predefined options. if choose "1" option then text as "C.BOX Room"
b)if choose "2", then room Name placed as "Gen.Room"
c) if Choose "3", then room name as "Waiting.Room"
d)if choose "4", then room name as "Conference.Hall"
e)if Choose "5", then Room name as "Kitchen.Room"
4) then develop room Dimension as (for Example, i choose "4"th option from command prompt),
Conference.Hall
28'0"x25'4½"
please see sample drawing.
Thanks.
Room dimension.dwg
  • Replies 31
  • structo
    15
  • maratovich
    10
  • AP Kumar
    2
  • ReMark
    1
Posted Images
Looks like you have some redundancy in the above image. You have the dimensions themselves and you call them out under the room name. Wouldn't one or the other suffice?
thank you friend for responding,
yes i need suffice of predefined room names by code. i need to automate several blocks or rooms by selecting two corners of the room or block.
Thank you.
Thank you.
almost similar old thread
you can tweak it yourself, many active members here will guide you
My shot at this:
(defun C:test ;| credits to: Lee Mac |; ( / Lst p1 p2 choice )
(setq Lst
		("1" . "C.BOX Room")
		("2" . "Gen.Room")
		("3" . "Waiting.Room")
		("4" . "Conference.Hall")
		("5" . "Kitchen.Room")
); setq
(if
	(and
		(setq p1 (getpoint "\nSpecify first point: "))
		(setq p2 (getcorner p1 "\nSpecify second point: "))
		(not (initget 1 (apply 'strcat (mapcar '(lambda (x) (strcat x " ")) (mapcar 'car Lst)))))
		(setq choice (getkword (strcat "\nSpecify option [" (vl-string-right-trim "/" (apply 'strcat (mapcar '(lambda (x) (strcat x "/")) (mapcar 'car Lst)))) "]: ")))
		(setq
			p1 (trans p1 1 0)
			p2 (trans p2 1 0)
	(entmakex
		(list
			(cons 0 "MTEXT")
			(cons 100 "AcDbEntity")
			(cons 100 "AcDbMText")
			(cons 10 (apply 'mapcar (cons '(lambda (a b) (/ (+ a b) 2.)) (list p1 p2))))
			(cons 1
				(strcat
					(cdr (assoc choice Lst))
					"\\P" (rtos (abs (apply '- (mapcar 'car (list p1 p2)))) 2 2) "x" (rtos (abs (apply '- (mapcar 'cadr (list p1 p2)))) 2 2)
			(cons 71 5)
Sorry we don't use imperial units, so someone else will have to fix that for you.
My shot at this:
wow, good shot Grr friend and Lee Mac friend,
i will wait for Feet and inches units ( imperial units) which is mentioned in sample drawing format.
Thank you.
hi hanh,
i saw your link. i need some tweaks from that thread.
1)please add room name description option.
2)text was developed as (For example) 12', instead of 12'-0"
Thank you.
Use this macro:
Dear Marat friend,
your macro is great working. especially GUI is awesome. my final request is if any possibilities, please tweak half inch display text format as shown in image.
Thank you for helping.
Edited by structo
New version:
Excuse me, but did not immediately understand.
replace the 1 \ 2 on the vertical division - it is long and difficult.
possible to do, but ...
I have a lot of work.
hi friend,
thank you for valuable reply. i apologies for inconvenience caused. here i have attached sample out put format. your previous version is enough (post#10). i have requested only vertical format (stacked format, it is showing option at medit window, by manual editing). please tweak when you have free time only.
Thank you for support.
See version 3
Thank you for yours valuable modification. some gap is formed as mentioned in picture. please modify.
sorry for asking modifications.
thank you.
Again sincere thanks to you friend,
still facing space issue by out put text, minor error. here i have attached image. please have a look.
Thank you for great contribution.
