OMEGA-ThundeR Posted December 14, 2016 Share Posted December 14, 2016 Hi, I am making a 3D design of some button layout and recreated a button i want to use in AutoCAD. The problem i have when rendering is that the render result looks as 'choppy' as the modelspace model. Why aren't my round shapes round and do they have 'corners' and 'curves' in them? i use the 'presentation' preset under RPREF, but it still turns out as crappy as the model space... What am i doing wrong? Is it a setting i forgot? The wireframe render has perfect round objects, but it gets more 'squared' on more detailed shadings. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 15, 2016 Share Posted December 15, 2016 Try setting VIEWRES to 10,000 and FACETRES to 10. Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted December 15, 2016 Author Share Posted December 15, 2016 Ok, i'll try that later tonight. However, as far as i can tell at my work this setting only changes the look in the modelspace. If i lower FACETRES round objects get more 'edgy', but in the render it still looks good. It might also be a difference in CAD version. At home i use 2015 and at work 2017... But i will find out tonight . Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 15, 2016 Share Posted December 15, 2016 What are the computer specifications? Does it happen at work and home? Can you post the .dwg? Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted December 15, 2016 Author Share Posted December 15, 2016 My home computer has a i7 4790k with 16gb ram and a AMD 290 GPU. Powerfull enough i recon. At work it's in Xeon E5-1620 V3, 32gb ram and Quadro M4000 GPU. The renders in the OP are made from home. I haven't tested it at work yet (forgot), i can try tomorrow. DWG i can supply this evening. Quote Link to comment Share on other sites More sharing options...
f700es Posted December 15, 2016 Share Posted December 15, 2016 Looks like you might have a Radeon R9 290 graphics card, which is a good card but pointless in this example as AutoCAD does not use the video card for rendering. It still uses the CPU. You have an i7 4790k which is a D@MN good cpu. It is a hyper-threaded quad core which will give you 8 rendering cores. It is also unlocked, shown by the "k" designation, which means that you can over clock it for more speed. Start with CAD64's advice and smooth out the image. You also need make adjustments in your lighting and perhaps materials. AutoCAD has a good rendering engine but it takes a bit of adjustments to get a good render. You have a good start so keep going http://www.cad-notes.com/autocad-2016-rendering/ Oops, I saw above you are using 2015 at home but in your profile it says 2016. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 16, 2016 Share Posted December 16, 2016 DWG i can supply this evening. Any update on this? Did you try what I suggested? That should fix the problem, but if it doesn't, post the drawing so we can take a look. Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted December 16, 2016 Author Share Posted December 16, 2016 I tried the settings but nothing changed... Used Autocad 2015 and Civil 3D 2017, and Autocad 2017 @ work. Even if i remove objects and only render the pushbutton or the body, still edgy. i've added the DWG file in a RAR archive.. it's just over 1 mb and couldn't upload otherwise. 3dbutton.rar Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 16, 2016 Share Posted December 16, 2016 It is small enough to post here. 3dbutton.dwg Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted December 16, 2016 Author Share Posted December 16, 2016 It was just over 1mb when i tried. But it's online now Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 16, 2016 Share Posted December 16, 2016 The problem is the button is too small, scale it up some and it looks correct. Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted December 16, 2016 Author Share Posted December 16, 2016 Hot damn! My units are off or i need to size things up... tried to draw in Meters (so a lot of 0.00x sizes)... But indeed it seems to make everything smooth again when sizing it up... Thanks, this makes my day . Quote Link to comment Share on other sites More sharing options...
