Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Full Member jaff's Avatar
    jaff's Computer Details
    Windows 10 Professional
    Dell OptiPlex 5040
    Version 10.0.10586 Build 10586
    Processor Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz, 3192 Mhz, 4 Core(s), 4 Logical Processor(s)
    Installed Physical Memory (RAM) 4.00 GB
    Adapter Type AMD Radeon Graphics Processor (0x6610), Advanced Micro Devices, Inc. compatible
    Size 453.24 GB NTFS (486,661,943,296 bytes)
    Dell E2213H
    Structural
    jaff's Discipline Details
    Engineer
    Structural
    Residencial Design, Low Rise Building Design
    AutoCAD LT 2017
    Jun 2013
    S.F. Bay Area
    60
    Default Zero feet and Zero in suppression
    Does any one knows how to suppress zeros in dimension dialog boxes? For example, for the dimension style (Se_DIM-12) the text height reads 0'-0 3/32" and I want it to read 3/32" (eliminate all the zeros) as in dimension style (DIM-12). See attached screen shots.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Did you check the units tab?
    Drafting is a breeze.
    Dell OptiPlex 5040
    Dell E2213H
    Structural
    Engineer
    Structural
    AutoCAD LT 2017
    Jun 2013
    S.F. Bay Area
    60
    Yes, I check the box for the Zero suppression but I do not think it has to do with this. I think is a system variable set or some type of setting that needs to be modified in the drawing.
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    That's it. You need to update the dimensions for the change to take affect.
  5. #5
    Dell OptiPlex 5040
    Dell E2213H
    Structural
    Engineer
    Structural
    AutoCAD LT 2017
    Jun 2013
    S.F. Bay Area
    60
    I did update the dimension but the values in the dialog box remain the same (0'-0 1/16" will not change to 1/16") it is not a big deal because my dimensions work fine is just annoying to me. I like to see things clean.
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Please post a file that is misbehaving. It should be working.
  7. #7
    AutoCAD 2013
    Nov 2011
    6,049
    On the Primary Units tab, set your Units format as Fractional, and select Leading Zero suppression, as shown in the screenshot...
    You may want to also apply Leading zero suppression in your angular dimensions.
  8. #8
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    That's one way. There are others. Funny thing is the images in the OP appear as though the zeros are being suppressed. I bet he was modifying the wrong dimstyle.
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,096
    RobDraw, Dadgad, I think you both have completely missed the question. The OP wants to suppress the zeros in the dialog box, not in the dimensions.
    Mine stay if I type in just 3/32", 1/8", etc. (or even .09375 or .125), though they default to leading zeros and will return if I just delete the zeros from what is the default. Not sure what drives the zero displays in the dialog boxes.
  10. #10
    AutoCAD 2013
    Nov 2011
    6,049
    Quote Originally Posted by SLW210 View Post
    SLW, yeah, having reread the thread, I believe you are correct.
    Rob in his screenshots, the dimension on the right side diagonal edge is displaying the unwanted leading zero.
    Now that I think I misread the problem, this doesn't really seem like a big problem, since as the OP says his actual dimensions are fine.
    I mistakenly thought THEIR display was the problem.
  1. Suppression of Command Line Activity During Lisp Processing
    By abra-CAD-abra in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jan 2015, 10:25 am
  2. From feet to meters
    By kililio in forum Revit General
    Last Post: 13th Mar 2013, 07:30 am
  3. Pasteclip Dialog Window Suppression
    By Bill Tillman in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Apr 2012, 06:35 pm
  4. Displaying Decimal Feet -- Entering Feet and Inches
    By Ethos Erlanger in forum AutoCAD General
    Last Post: 31st May 2011, 09:36 pm
  5. Zero suppression setting is not saved in dimension style
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 16th Feb 2007, 02:11 am
