Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Forum Newbie
    Civil
    AutoCAD 2016
    Dec 2016
    2
    Default Draw circles in multiple points
    Hi,
    I want to make a script who draw circles in multiple Points. The Points are automaticly made in a extension to autocad. All the Points are in same layers. It´s around 200 to 1000 Points in the drawing.
    My first issue is to find a commando who draw circles, with basepoints in all Points.
    Does anyone know the appropriate command for me?
    Regards,
    Emil
    Super Member
    not specified
    Dec 2004
    YUL
    587
    This is what I use.
    Code:
    (defun c:ic (/ a b c r d n p d1 d2 e1 cl oerr osn)
      (setq osn (getvar "osmode"))
      (setvar "cmdecho" 0)
      (setq cl (getvar "clayer"))
      (if c
        (setq c 1.0)
      (princ "\n Circle diameter < ")
      (princ c)
      (princ " > ? ")
      (setq b (getdist))
      (if (= b nil)
        (setq b c)
        (setq c b)
      (setq r (/ b 2))
      (princ "\n Select nodes ")
      (setq a (ssget '((0 . "POINT"))))
      (setq d (sslength a))
      (setq d1 d)
      (repeat d
        (setq d2 (1- d1))
        (setq n (ssname a d2))
        (setq e1 (entget n))
        (setq p (cdr (assoc 10 e1)))
        (entmake (list (cons 0 "CIRCLE")
    		   (cons 6 "BYLAYER")
    		   (cons 8 cl)
    		   (cons 10 p)
    		   (cons 40 r)
    		   (cons 210 (list 0.0 0.0 1.0))
        (entdel n)
        (setq d1 d2)
      (setvar "osmode" osn)
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Maybe a slight simplification of code
    Code:
      (setq d1 d)
      (repeat d
        (setq d2 (1- d1))
      (repeat (setq d2 (sslength a)))
        (setq e1 (entget (ssname a (setq d2 (- d2 1)))))
    Senior Member satishrajdev's Avatar
    satishrajdev's Computer Details
    Windows 7 - 64bit
    DELL
    8 GB
    500 GB
    DELL
    Surveying
    satishrajdev's Discipline Details
    CAD Engineer
    Surveying
    Design Survey Utilities (i.e. Bathymetry & Geophysical Survey) Design of Survey Planning. Preparation of Alignment Sheets. Programming in AutoCAD.
    AutoCAD 2014
    Apr 2012
    Aamchi Mumbai, India
    451
    Another one
    Code:
    (defun c:test (/ a b i)
      (if (and (setq a (ssget '((0 . "point"))))
    	   (setq b (getdist "\nSpecify Circle Radius : "))
        (repeat (setq i (sslength a))
          (entmakex
    	      (assoc 10 (entget (ssname a (setq i (1- i)))))
    	      (cons 40 b)
    Best Regards,
    Satish Rajdev
    If you ride like there is no tomorrow... Don't worry, there won't be !!!!
    www.facebook.com/satish.rajdev
  5. #5
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    @Satish, Note that:
    Code:
    (cons 10 (cdr (assoc 10 <list>))) == (assoc 10 <list>)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  6. #6
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,478
    I remember someone wrote an algorithm for spacing circles within range (not sure if it was Marko).
    Can't seem to find it right now.
  7. #7
    Windows 7 - 64bit
    DELL
    8 GB
    500 GB
    DELL
    Surveying
    CAD Engineer
    Surveying
    AutoCAD 2014
    Apr 2012
    451
    Quote Originally Posted by Lee Mac View Post
    @Satish, Note that:
    Code:
    Thanks you sir. I need to be more focused on this
    BTW I have updated the code.
    Best Regards,
    Satish Rajdev
  8. #8
    Forum Newbie
    Civil
    AutoCAD 2016
    Dec 2016
    2
    Thanks so much.
    It works good!
    Quote Originally Posted by satishrajdev View Post
    Another one
    Code:
          (entmakex
              (cons 40 b)
    Windows 7 - 64bit
    DELL
    8 GB
    500 GB
    DELL
    Surveying
    CAD Engineer
    Surveying
    AutoCAD 2014
    Apr 2012
    451
    Best Regards,
    Satish Rajdev
  10. #10
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    FWIW, here's another version which will retain the original properties of the points, and will account for points constructed in any UCS plane:
    Code:
    (defun c:p2c ( / c i r s x )
        (if (and (setq s (ssget '((0 . "POINT"))))
                    (initget 6)
                    (setq r (getdist "\nSpecify circle radius: "))
            (repeat (setq i (sslength s))
                (setq x (reverse (entget (ssname s (setq i (1- i)))))
                      c (assoc 10 x)
                (entmake
                    (subst '(0 . "CIRCLE") '(0 . "POINT")
                        (subst (cons 10 (trans (cdr c) 0 (cdr (assoc 210 x)))) c
                            (reverse
                                (cons (cons 40 r)
                                    (vl-remove-if '(lambda ( x ) (member (car x) '(50 102 360))) x)
  1. Convert multiple circles into points
    By LEIGH in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jan 2016, 06:36 am
  2. Circles to Points
    By big daddy in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Apr 2009, 10:00 pm
  3. Circles to Points
    By big daddy in forum AutoCAD General
    Last Post: 24th Dec 2008, 07:57 pm
  4. Going in circles trying to draw an arc in 3D
    By Gerhard van Eeden in forum AutoCAD Beginners' Area
    Last Post: 5th Jun 2008, 05:38 pm
  5. draw circles through points
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2006, 05:50 am
Tags for this Thread
