HIRSTY1997 Posted January 5, 2017 Share Posted January 5, 2017 i would like to know how to scale a block posted below i would like to be able to have a drag feature that makes the block bigger in the x axis only this will also scale the spline in the middle of the block in the x axis only. M0213.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 5, 2017 Share Posted January 5, 2017 Unfortunately that's not an available option in a dynamic block, the scale option will work on both the X and the Y directions, you can scale a block in just a single axis from the properties palette but this will result in the block no longer being dynamic, and isn't available as a drag-able method. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 6, 2017 Share Posted January 6, 2017 Like steven you could change the x scale but the block would need to be like a 1x1 size so scale factor is actual size, 2nd idea is base point is left bottom pick point to right and scale is reworked out based on distance from insertion point to new point, this should work with a non square block. Its based on known size of block at scale x=1. Quote Link to comment Share on other sites More sharing options...
