Results 1 to 5 of 5
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Default JPEG Xrefs as Overlay vs Attachment?
    Hi all!
    So, lets say I have drawing "A" as an xref in drawing "B". I then want to xref drawing "B" in drawing "C". If I don't want "A" to show up in "C", I simply make sure that it's an overlay not an attachment in "B". All good.
    Now let's say that there are also a bunch of pictures (jpeg files) xref'd into "B". If I don't want these showing up in "C", there doesn't appear to be the option to make them overlays like with dwg files.
    So, is it possible to xref a drawing that has xref'd images without pulling those along too?
    Thanks!
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Can you unload them in the XREF manager in File B?
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Yes, and sorry I should have mentioned that. While that is an obvious and relatively pain-free work around, I'd like them to not show up at all. But you're right, I guess worst-case scenario, there's just a few more clicks.
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    I thought of a LISP I use from our member alanjt:
    http://www.cadtutor.net/forum/showth...ponding-layers
    It's a valuable part of my daily LISP routine library but I don't think it'll work with images. I'm going to post in that thread to request if this can be updated to include images and/other items. This may be a good solution too since you can simply Freeze the layer very quickly after running this LISP, and if this is normal workflow that can be embedded in a template, even better.
    -TZ
  5. #5
    Full Member
    Civil
    AutoCAD 2015
    May 2016
    79
    Thanks! I'll look into it. Appreciate the advice and the request on that forum.
  1. Attachment to Overlay
    By zitronet in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Feb 2012, 01:43 am
  2. Check XRefs for 'Attach' or 'Overlay'
    By harilalmn in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Aug 2011, 08:23 am
  3. Flag for Overlay vs. Attachment
    By CHLUCFENG in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jun 2010, 12:18 am
  4. Difference between attachment & overlay
    By rengised in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jun 2010, 06:23 pm
  5. X-ref.. Attachment Or Overlay
    By T704 in forum AutoCAD General
    Last Post: 14th Apr 2010, 08:08 pm
Tags for this Thread
