Results 1 to 5 of 5
    Super Member
    AutoCAD 2010
    Dec 2010
    1,203
    Default components merge up
    hi
    im new to revit,
    i draw a wall, than i draw a column attached to it.
    when they are connected, they somehow merges into one,
    in the attached image you can see the same geometry, on the right what happened when they are apart, and on the left what happen when i connect them.
    what is this?
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,067
    There are two types of columns in Revit and they behave differently: Architectural and Structural Columns. Architectural columns will merge with walls, and structural columns won't. See example here:
    http://i.imgur.com/GVz81yP.png
    Hope this helps.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Super Member
    AutoCAD 2010
    Dec 2010
    1,203
    i see
    when im tring to add Structural Columns revit say that they are not loaded. how can i load them?
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,067
    At the time of the alert, there should be a Yes/No option to load them. But you can load Families at any time from the ribbon under Insert > Load Family. You can also Drag/Drop Families in from Windows Explorer. The default installation directory of Families are usually found here:
    Code:
    C:\ProgramData\Autodesk\RVT <YYYY>\Libraries\US Imperialmperial
  5. #5
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,067
    Also, have you thought about picking up a book for the basics? These few questions you have had are the absolute bare fundamentals. A read through a good basics book would get you humming along in no time.
    -TZ
  1. Replies: 6
    Last Post: 22nd Feb 2011, 11:27 pm
  2. CADVENT - own components
    By floowkid in forum Design Software
    Last Post: 14th Feb 2011, 11:26 am
  3. Components? tell me about them?
    By gcp310 in forum SketchUp
    Last Post: 8th Sep 2010, 03:50 am
  4. Moving around components?
    By robertf in forum Electrical
    Last Post: 4th Nov 2008, 03:32 am
  5. SketchUp Components
    By CADken in forum SketchUp
    Last Post: 24th Jun 2008, 01:20 am
